AGX Orin Dev kit has got the kernel panic
We have 2ea of Jetson AGX Orin Developer Kit.
The one of them has a issue.
It can’t boot and the flashing is failed.
Please, check the boot log and flash log.
boot_log.txt (105.8 KB)
sdkm-2023-02-21-18-29-37.log (937.0 KB)
Please, check the problem.
Is that host machine a ubuntu 18.04 or 20.04 one? If it is 20.04, could you also use a 18.04 host to flash too?
Also, what board config did you choose when you flash the board?
Could you also try to use jetson-agx-orin-devkit-as-jao-32gb to flash and see if that works?
It’s OK with ubuntu 18.04 host pc.
