We are using the AGX Orin SOM with our custom carrier board running Jetson Linux R35.5.0. As previously discussed in this post: AGX Orin Custom Carrier Board Boot Time Issue, we are facing a long boot time issue.
Our custom board (0004) takes almost 2 minutes and 43 seconds. to boot, while the same code flashed on the EV kit (0000) boots in less than a minute. Custom board boot log.txt (138.7 KB) EVK boot log.txt (124.6 KB)
I’ve attached both boot logs with timestamps for your reference.
Could you provide any guidance on why the custom board is experiencing this delay and how to resolve it?
Yes, I have followed the quick start guide and flashed the system as instructed, which is why I attached the logs.
The custom board is taking a long time to boot, as shown in the log excerpts below:
Custom Board Log:
[2024-10-11 17:27:52] E/LD: init_elf:486 sys_open_ta_bin(bc50d971-d4c9-42c4-82cb-343fb7f37896)
[2024-10-11 17:27:52] E/TC:?? 00 ldelf_init_with_ldelf:131 ldelf failed with res: 0xffff000c
[2024-10-11 17:29:18] ESC to enter Setup.
[2024-10-11 17:29:18] F11 to enter Boot Manager Menu.
[2024-10-11 17:29:18] Enter to continue boot.
EV Kit Log:
[2024-10-15 19:09:44] E/LD: init_elf:486 sys_open_ta_bin(bc50d971-d4c9-42c4-82cb-343fb7f37896)
[2024-10-15 19:09:44] E/TC:?? 00 ldelf_init_with_ldelf:131 ldelf failed with res: 0xffff000c
[2024-10-15 19:09:52] ESC to enter Setup.
[2024-10-15 19:09:52] F11 to enter Boot Manager Menu.
[2024-10-15 19:09:52] Enter to continue boot.
As you can see, even without modifying any code, the custom board takes significantly longer to boot than the EV kit, despite both using the same UEFI version:
Custom Board UEFI Version:
Jetson UEFI firmware (version 5.0-35550185 built on 2024-02-20T04:21:22+00:00)
EV Kit UEFI Version:
I would appreciate any insights you may have regarding this issue.
I cloned the edkrepo, removed the .inf file as mentioned in the wiki, generated the uefi_Jetson_DEBUG.bin, copied it to the bootloader path, and re-flashed the board. However, it still takes a long time to boot.
Here is the boot delay log for your reference:
[2024-10-16 19:17:09] add-symbol-file /home/parashuram/uefi_code/nvidia-uefi-r35.5.0/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/AndroidBootDxe/AndroidBootDxe/DEBUG/AndroidBootDxe.efi
[2024-10-16 19:17:09] Loading driver at 0x0082615D000 EntryPoint=0x008261643A8 AndroidBootDxe.efi
[2024-10-16 19:17:09] add-symbol-file /home/parashuram/uefi_code/nvidia-uefi-r35.5.0/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/PcieControllerDxe/PcieControllerDxe/DEBUG/PcieControllerDxe.efi
[2024-10-16 19:17:09] Loading driver at 0x0082614A000 EntryPoint=0x008261561B4 PcieControllerDxe.efi
[2024-10-16 19:17:10] add-symbol-file /home/parashuram/uefi_code/nvidia-uefi-r35.5.0/Build/Jetson/DEBUG_GCC5/AARCH64/SecurityPkg/Hash2DxeCrypto/Hash2DxeCrypto/DEBUG/Hash2DxeCrypto.efi
[2024-10-16 19:17:10] Loading driver at 0x0082613F000 EntryPoint=0x00826144D58 Hash2DxeCrypto.efi
[2024-10-16 19:17:10] add-symbol-file /home/parashuram/uefi_code/nvidia-uefi-r35.5.0/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/EqosDeviceDxe/EqosDeviceDxe/DEBUG/EqosDeviceDxe.efi
[2024-10-16 19:17:10] Loading driver at 0x008260A5000 EntryPoint=0x008260AC4A8 EqosDeviceDxe.efi
[2024-10-16 19:17:37] SNP:PHY: PhyDxeInitialization () Failed to reset Phy
[2024-10-16 19:17:37] DeviceDiscoveryBindingStart, driver returned Device Error to start notification
[2024-10-16 19:18:04] SNP:PHY: PhyDxeInitialization () Failed to reset Phy
[2024-10-16 19:18:04] DeviceDiscoveryBindingStart, driver returned Device Error to start notification
[2024-10-16 19:18:04] add-symbol-file /home/parashuram/uefi_code/nvidia-uefi-r35.5.0/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/NonDiscoverablePciDeviceDxe/NonDiscoverablePciDeviceDxe/DEBUG/NonDiscoverablePciDeviceDxe.efi
[2024-10-16 19:18:04] Loading driver at 0x0082609A000 EntryPoint=0x008260A08CC NonDiscoverablePciDeviceDxe.efi
Even after removing # Silicon/NVIDIA/Drivers/EqosDeviceDxe/EqosDeviceDxe.inf, the delay remains the same. custom_boot.log (277.5 KB)
I would appreciate any further insights you may have regarding this issue.
The system is now working fine with reduced boot time. Thank you for your support.
I would like to know how to disable the UEFI boot log from being displayed during boot using the custom compiled edk2-nvidia source. I no longer need the UEFI logs to appear during boot.
Does removing the EqosDeviceDxe.inf affect any other part of the code, such as the 1G network or any other network ports?
Yes, EqosDeviceDxe may affect the function of ethernet.
There are still some methods in the guide I shared to reduce the boot time.
Have you also tried each of them?
You can just use uefi_Jetson_RELEASE.bin instead of uefi_Jetson_DEBUG.bin if you don’t need the debug messages.
Is there any solution to resolve this issue? I’d like to understand what’s causing the delay and what is happening with the EqosDeviceDxe that affects the 1G Ethernet functionality. Is there a timeout function or any other factor causing the delay, and if so, how can we address it?
Apart from the methods mentioned in the wiki, is it possible to reduce the boot time without impacting the 1G Ethernet?
