We encountered a problems when using AGX for PCIe Compliance testing,The PCIe signal will only be generated at the beginning of system startup when connected test fixtures, but it cannot be maintained.
I have referred to the content of the PCIe test in 《Jetson_AGX_Xavier_Series_Tuning_and_Compliance_Guide_DA-09855-001_v1.2》,"To keep the PCIe controller enabled, the patch (rel-32_Xavier.diff) attached to this application note should be applied.",
Is this the cause of the problem?Where can I get the patch?
The patch is attached in the “attachment” of doc.
