Hi
We are running the PCIe TX SI test, but no signal generate from Xavier when connect test fixture. Do we need other PCIe SI test command or tool can into test mode?
You can refer the schematic from CPU side, thanks.
Leif
Hi
Leif
Please refer to the PCIe test chapter in tuning guide: https://developer.nvidia.com/jetson-agx-xavier-series-tuning-and-compliance-guide-application-note
Hi
How can I get the 92faa4d.diff file on PDF?
I can’t find the it, thanks.
Leif
The patch will be added into pdf file soon, please wait for the update, thanks.
Hi
Does it update into the pdf file?
It will be updated into pdf file in DLC.
Hi
Can you give the hyperlink if it’s ready?
Same doc as previous listed https://developer.nvidia.com/jetson-agx-xavier-series-tuning-and-compliance-guide-application-note
