我们自研的AGX T5000主板,启动报错Failed to get eeprom handle for cvb from eeprom manager. 但是我已经按照文档修改了cvb_eeprom_read_size = <0x0>;并且在p3834-0008-p4071-0000-nvme.conf 下添加了SKIP_EEPROM_CHECK=1; 所以想问下为什么会出现这种情况,是否有其他地方需要修改?麻烦帮忙看下
WayneWWW
4
How many tegra264-mb2-bct-common.dtsi files are there under your Linux_for_Tegra/bootloader directory?
有两个,一个在bootloader 一个在bootloder/generic/BCT 现在问题已经解决
Related topics
| Cvm eeprom fails to read during boot | 2 | 289 | January 6, 2025 | |
| Jetson AGX Orin booting fail on custom carrier board without EEPROM | 2 | 734 | April 7, 2023 | |
| AGX Orin getting stuck booting on a custom board | 1 | 189 | June 23, 2025 | |
| Jetson AGX Orin not booting on custom carrier board without EEPROM | 2 | 3167 | September 19, 2022 | |
| EEPROM Corruption on Jetson AGX Orin Industrial 64GB Developer Kit – Flash Failure and Boot Issues | 1 | 280 | May 28, 2025 | |
| Jetson AGX Orin not booting on custom carrier board with EEPROM (AT24C02 with address: 0x56) | 5 | 414 | October 30, 2024 | |
| 在 jetpack 6.2.1 版本下,如何让没有 eeprom 的载板正常启动 | 5 | 368 | February 3, 2026 | |
| 在自定义载板启动时,开在busy spin | 20 | 765 | February 20, 2025 | |
| jetpack7.1,T5000,eeprom,flash failed | 11 | 416 | February 9, 2026 | |
| Devkit used as carrier board without eeprom | 3 | 585 | April 12, 2023 |
