i am using jetpack7.,the customized carrier board, external SSD FLASH,but there is an error
i modify the follow file ,and this flash command,but it still report the same error
sudo SKIP_EEPROM_CHECK=1 BOARDID=3834 BOARDSKU=0008 ./l4t_initrd_flash.sh jetson-agx-thor-devkit internal
$ vi Linux_for_Tegra/bootloader/generic/BCT/tegra264-mb2-bct-misc-p3834-0008-p3740-0002.dts
$ vi Linux_for_Tegra/bootloader/generic/BCT/tegra264-mb2-bct-common.dtsi
$ vi Linux_for_Tegra/bootloader/tegra264-mb2-bct-common.dtsi
-cvb_eeprom_read_size = <0x100>
+cvb_eeprom_read_size = <0x0>
Hi asdfqq55,
Have you also tried flashing Jetpack 7.0(r38.2.0) and hit the similar issue?
Could you add SKIP_EEPROM_CHECK=1 to the board config(jetson-agx-thor-devkit.conf) and run the following command to flash instead?
$ sudo ./l4t_initrd_flash.sh jetson-agx-thor-devkit internal
[flash.log|attachment](upload://biBXDXQ4mPLk4HpHJP9GDh97a1B.lo
NOW,i use the same flash command to the version 38.04 and 38.02 :sudo SKIP_EEPROM_CHECK=1 BOARDID=3834 BOARDSKU=0008 ./l4t_initrd_flash.sh --external-device nvme0n1p1 jetson-agx-thor-devkit internal
at the same time,i modify this file :jetson-agx-thor-devkit.conf
the logs as follow:
38.04:
38.04_COM.txt (29.5 KB)
38.04_flash.log (221.6 KB)
38.02:
3802_COM.log (26.5 KB)
3802_flash.log (188.9 KB)
Don’t know that it will matter, but jp7/Linux_for_Tegra/tools/kernel_flash/README_initrd_flash.txt suggests following command for external nvme0n1p1.
The ADDITIONAL_DTB_OVERLAY_OPT=“BootOrderNvme.dtbo” is optional but I believe keeps ip devices from being at top of boot devices in uefi. And —showlogs is nice to have.
sudo ADDITIONAL_DTB_OVERLAY_OPT="BootOrderNvme.dtbo" ./l4t_initrd_flash.sh \
--external-device nvme0n1p1 [ -c ./tools/kernel_flash/flash_l4t_t264_nvme.xml ] \
--showlogs jetson-agx-thor-devkit internal
i use this command ,i add options ADDITIONAL_DTB_OVERLAY_OPT, --showlogs
sudo SKIP_EEPROM_CHECK=1 ADDITIONAL_DTB_OVERLAY_OPT=“BootOrderNvme.dtbo” ./l4t_initrd_flash.sh --external-device nvme0n1p1 -c tools/kernel_flash/flash_l4t_t264_nvme.xml --showlogs jetson-agx-thor-devkit internal
the log as follow:
3804_COM_showlog.log (9.2 KB)
3804_flash_showlog.log (70.5 KB)
My host workstation is turned off so I can’t state correct directories. So that flash would create dtb that include it, have you deleted the, (I think it is) bootloader/output directory and the other flash created subdirectory beneath preexisting unified_flash directories
subsequent to the time you did?
- cvb_eeprom_read_size = <0x100>
+ cvb_eeprom_read_size = <0x0>
sorry,my custom carrier is the first flash, i only modify this relating file ,no other operation.
I don’t even know about these files you mentioned.
- cvb_eeprom_read_size = <0x0>
If you are using the custom carrier board w/o EEPROM on this board, please do the following 2 modification.
- Add
SKIP_EEPROM_CHECK=1 to board config
- update MB2-BCT by referring to the following instruction
Jetson Thor Adaptation and Bring-Up — Modifying for EEPROM
Please just use the following command to flash the board w/o specifying the BOARDID and BOARDSKU.
i have tried in this method ,but it still report the log in the vesion 38.4,it is ok in 38.2
Please provide the following information for further check.
- <Linux_for_Tegra>/bootloader/generic/BCT/tegra264-mb2-bct-common.dtsi
- <Linux_for_Tegra>/bootloader/jetson-agx-thor-devkit.conf
- flash log as file with the exact flash command used
jetpack7.1,T5000,custom carrier board,
1.<Linux_for_Tegra>/bootloader/generic/BCT/tegra264-mb2-bct-common.dtsi :in the file bootloader.zip
bootloader.zip (11.8 KB)
- <Linux_for_Tegra>/bootloader/jetson-agx-thor-devkit.conf :
3.the flash command:
sudo ADDITIONAL_DTB_OVERLAY_OPT=“BootOrderNvme.dtbo” ./l4t_initrd_flash.sh --external-device nvme0n1p1 -c tools/kernel_flash/flash_l4t_t264_nvme.xml --showlogs jetson-agx-thor-devkit internal |tee flash_202602061450.log
4.the logs:
[Com COM3] (2026-02-06_145737).log (18.3 KB)
flash_202602061500.log (210.2 KB)
Could you try using the following command to flash the board instead?
In this flash log, it seems flashing process ends at system.img creation rather than the CVB EEPROM reading.
