Hi Nvidia Team,
I am trying to flash a fresh nvidia thor module with my custom carrier board with JP 7.2. The custom carrier board has an epprom and 2 i2c based gpio expanders on the same i2c bus as the CVB eeprom.
Flash command used is:
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -c tools/kernel_flash/flash_l4t_t264_nvme.xml --showlogs --network usb0 jetson-agx-thor-devkit external
I am facing below error:
flash_error.txt (30.8 KB)
Can you please help in resolving this error at the earliest.
Regards,
please still set the cvb_eeprom_read_size to 0 in the t264 mb2 bct config dtsi file.
Hi @WayneWWW , Let me check with this, also in debug logs seeing following error
"I> Populate chip info
C> RAM_CODE 0xc
I> Populate Boot device info
I> Boot device type information 0x3
I> boot device info return size =0x2
I> Populate eeprom info
I> Populate eeprom info for module cvm
I> command: dump sub-command: 0
I> dump bct
E> LOADER: Invalid value Header magic.
E> Validation failed for 1 copy of BRBCT @ 0
E> Validation failed for 2 copy of BRBCT @ 262144
E> Validation failed for 3 copy of BRBCT @ 524288
E> Validation failed for 4 copy of BRBCT @ 786432
E> NV3P_SERVER: Failed to get address for br bct from nv3p helper."
Please make sure you did these steps mentioned in document.
Hi @WayneWWW , i was able to resolve the eeprom related error, but currently facing error following:
[0006.291] I> NVRNG: Health check success
[0006.303] I> Task: Prepare Hafnium params
[0006.314] I> haf_params = 0x1f9b000000
[0006.323] I> BL32 EP param-hdr (type: 0x1, version: 0x1, size: 0x58, attr: 0x0)
[0006.330] I> BL32 EP PC: 0x1f9b010000
[0006.333] I> BL32 EP SPSR: 0x3c9
[0006.336] I> BL32 EP X0: 0x1f9ce10000
[0006.340] I> BL32 EP X1: 0x0
[0006.343] I> BL32 EP X2: 0x1f9b000000
[0006.347] I> BL32 EP X3: 0xcafebabe
[0006.350] I> BL32 EP X4: 0x0
[0006.353] I> BL32 EP X5: 0x0
[0006.356] I> BL32 EP X6: 0x0
[0006.359] I> BL32 EP X7: 0x0
[0006.362] I> PC INFO from epinfo = 0x14000010
[0006.366] I> BL32 IMG param-hdr (type: 0x0, version: 0x0, size: 0x0, attr: 0x0)
[0006.373] I> BL32 IMG image base: 0x1f9b010000
[0006.377] I> BL32 IMG image size: 0x395c0
[0006.381] I> Task: Prepare ATF params
[0006.384] I> NVRNG: Health check success
[0006.391] I> NVRNG: Health check success
[0006.392] I> Skipping 'tid-table-addr' update in ATF DTB
[0006.397] I> BL31 param-hdr (type: 0x0, version: 0x0, size: 0x0, attr: 0x0)
[0006.404] I> BL31 IMG param-hdr (type: 0x0, version: 0x0, size: 0x0, attr: 0x0)
[0006.411] I> Task: OEM SC7 context save
[0006.415] W> DRAM bad page list is empty!
[0006.472] I> OEM_SC7 context data saved
[0006.472] I> Task: Clear dec source key
[0006.472] I> Task: Apply HWPM conf��init��ig
��2] I��[000��zed ��6.47��emc
��> Skipping - not in ODM prod mode
[0006.472] I> Task: Program OEM firewalls - late boot
[0006.478] I> OEM firewalls configured
[0006.484] I> Task: SMMU restore
[0006.487] I> Task: Program GICv3 registers
[0006.491] I> Task: Disable Interrupt for NSR IP's
[0006.495] I> Task: Audit firewall settings
[0006.499] I> Task: Trigger tsec mailbox for PSC-fw exit
[0006.509] I> Task: Compute cpubl params hash
[0006.510] I> Added cpubl params hash.
[0006.513] I> MB2 finished
��initialized avfs_clk_platform
initialized powergate
initialized dvs
initialized clk_mach_config
suspend progress: 0x0
initialized suspend
initialized strap
initialized emc_late
initialized emc_mrq
��[TS:5857831484705996800]Admin Task Init
[TS:5859189927027146752]Admin Task Init complete
[TS:5860352866731950080]Print Task Init
[TS:5861722445903298560]RM Task Init
[TS:5671099008]Admin Task Started
��sabl��34619��init��3]DC��iali��E SC��zed ��7 SH��clk_��A Di��cal
ini��ed
��tial��[TS:��ized��5672�� uph��0868��y_dt��41]R��
in��M Ta��itia��sk S��lize��tart��d pc��ed
��ie_d��[TS:��t
��5672232350]RM Task Running [id:2]
��Enable UPHY1 PLL 3 timeout UPHY_PLL_STATUS 0xa00
in��
I am not sure which config leads to this error, can you help the earliest
check if you are the same design as this post.
We have designed the custom carrier board for Thor T5000 module.
Module gets powered perfectly and goes in USB recovery mode without any issue. when we try to flash we get below error and then module goes in shut down.
When this issue occurs we checked all the power supply and found that all the module power and carrier board power turned off. After that when i press power button it turns on again which clearly shows that Thor module commanded the Power button MCU to turn off all the powers at…
