Thor: Modifying for EEPROM failed
according to the page: Jetson Thor Adaptation and Bring-Up — NVIDIA Jetson Linux Developer Guide
modify eeprom for our custom board.
Linux_for_Tegra/bootloader/generic/BCT/tegra264-mb2-bct-common.dtsi:
- cvb_eeprom_read_size = <0x100>
+ cvb_eeprom_read_size = <0x0>
then reflash the module:
sudo ./l4t_initrd_flash.sh jetson-agx-thor-devkit internal
but still report error, like this:
[0002.145] I> Task: Prepare eeprom data
[0002.170] E> I2C: slave not found in slaves.
[0002.171] E> I2C: Could not write 0 bytes to slave: 0x00ac with repeat start true.
[0002.172] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.174] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xac at 0x00000000 via instance 1.
[0002.183] E> eeprom: Retry to read I2C slave device.
[0002.189] E> I2C: slave not found in slaves.
[0002.193] E> I2C: Could not write 0 bytes to slave: 0x00ac with repeat start true.
[0002.200] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.206] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xac at 0x00000000 via instance 1.
[0002.215] E> eeprom: Failed to read I2C slave device
[0002.220] E> CPUBL: CVB eeprom not found in h&.
[0002.224] C> Task 0x3e failed (err: 0x4f1e050d)
[0002.229] E> Top caller module: CPUBL, error module: I2C, reason: 0x0d, aux_info: 0x05
attached file is the full output.
MobaXterm_COM3USBSerialPortCOM3_20250918_153115.txt (48.4 KB)
Do you have NV devkit to check if you could do the same setting and flash?
after modified the 3 below files, reflash the Thor on the custom board, it passed the eeprom error:
$ grep -Rls “cvb_eeprom_read_size” Linux_for_Tegra/bootloader/ | grep tegra264
Linux_for_Tegra/bootloader/tegra264-mb2-bct-common.dtsi
Linux_for_Tegra/bootloader/generic/BCT/tegra264-mb2-bct-misc-p3834-0008-p3740-0002.dts
but which one is the keypoint? please help to have a check, thanks.
This one is the original file.
This one is the copy.
When a copy exists, changing the content to the original one won’t take effect.
