THOR board flashing failed
Using the customer’s own carrier board, burn UEFI and system to THOR in recovery mode, print via debug serial port, and display Validation failed
thor flash uart print.log (41.3 KB)
Did you modify the BRBCT configuration?
Please install SOM on a developer kit and check if the issue occurs.
  1. BRBCT has not been modified
  2. Modules can be installed with UEFI and system on the development kit.
  3. The BRBCT failed when using our self-designed carrier board, and the timing was controlled by Power_good when the carrier board was powered on. 3.3V is powered on 180ms earlier than 12V.
机翻 · 通用领域
  1. Our carrier board does not have EEPROM (which has been removed from the configuration file);
  2. There are PCIe Switch, USB-Hub, and XFI (PHY) on the carrier board
Is the BRBCT configuration related to the carrier board? In other words, if the carrier board is different, the configuration needs to be modified accordingly
