The custom board failed to boot
We are currently debugging a custom board, which is stuck at the following log position.
It can be powered on, but it drops almost in a second.
[0000.098] I> MB1 (version: 0.23.0.1-t264-75019003-35ec65c7)
[0000.098] C> Boot-mode : Coldboot
[0000.098] C> MB1 last_boot_error: 0x0
[0000.099] I> Entry timestamp: 0x00014538
[0000.101] C> rst_source: 0x0, rst_level: 0x0
[0000.105] I> BR-BCT: preprod_dev_sign: 0
[0000.109] I> Socket mask: 0x1
[0000.111] I> Socket id: 0
[0000.114] I> Chip supports UFS HS mode
[0000.117] I> BR last_boot_error0: 0x0
[0000.121] I> BR last_boot_error1: 0x0
[0000.124] I> BR last_boot_error2: 0x0
[0000.128] I> NVBCT is initialized
[0000.131] I> Task: PSC Mailbox init
[0000.135] I> Task: Bootchain select WAR set
[0000.138] I> Task: Bootchain update marker
[0000.142] I> Task: Send error information to MCU
[0000.147] I> Task: CRC check
[0000.150] I> Task: CRC Integrity check
[0000.153] I> Task: Bootrom patch record validation and params check
[0000.159] I> Task: CRC Integrity check
[0000.163] I> Task: SMN Transfer check
[0000.166] I> Task: Initialize UTMI PLL
[0000.170] I> Task: Initialize REF_UFS PLL
[0000.175] I> Task: Crypto init
[0000.176] I> Task: Boost clocks
[0000.180] I> tegrabl_clk_print_clock_freq not supported
[0000.184] I> mb1_clocks_soc_boost_clocks: Switch BPMP_CPU_NIC to NAFLL
[0000.192] I> mb1_clocks_soc_boost_clocks: CLK_SOURCE_AXI_CBB 0x0, bct.axi_cbb_clk_divisor 0
[0000.199] I> Task: Perform MB1 KAT tests
[0000.204] I> Task: Secure debug controls
[0000.207] I> Task: Program NV master stream id
[0000.211] I> Task: Enabling and initialization of MSS Bandwidth limiter
[0000.217] I> No request to configure MBWT settings for any PC!
[0000.223] I> Task: Verify boot mode
[0000.227] I> Task: Alias fuses
[0000.230] I> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0000.236] I> Task: Print SKU type
[0000.240] I> SKU: Floorswept F1
[0000.242] I> Task: Recalibrate SOC vmon
[0000.246] I> vmon adc_cal_revision 4,  min_adc_fuse_rev 1
[0000.252] I> SOC VMON: min_reset 0, max_reset 0
[0000.256] I> SOC VMON ADC_SETUP: 0x00000000 to 0xc0000000
[0000.261] I> SOC VMON: Vmon re-calibration and fine tuning done
[0000.267] I> SOC VMON: min_reset 0, max_reset 0
[0000.271] I> Task: Select UFS ref clk
[0000.275] I> UFS device reference clock programmed to 26 MHz
[0000.280] I> Task: PMC AUX Clamp
[0000.283] I> Task: UPHY lane resets
[0000.287] I> Task: UPHY init
[0000.289] I> Configuring uphy in rate B
[0000.294] I> tegrabl_clk_print_clock_freq not supported
[0000.298] I> PLL3 ownership is assigned to PCIE
[0000.304] I> tegrabl_clk_print_clock_freq not supported
[0000.309] I> mphy_nv_calib_rev : 0, mphy_nv_calib_aux_val : 0
[0000.313] I> Enabling PLL with id : 3
[0000.317] I> Enabling PLL with id : 4
[0000.321] I> Skipping uphy_instance 1. Not supported yet
[0000.325] I> Skipping uphy_instance 2. Not supported yet
[0000.330] I> Task: Boot device init
[0000.334] I> Boot_device: QSPI_FLASH instance: 0
[0000.338] I> Using QSPI flash params from bct!!
[0000.342] I> PLLC is already locked
[0000.346] I> Qspi clock source : pllc_out0
[0000.350] I> QSPI Flash: Macronix 64MB at index: 5
[0000.355] I> QSPI-0l initialized successfully
[0000.358] I> Task: TSC init
[0000.361] I> Task: Load membct
[0000.364] C> RAM_CODE 0xc
[0000.366] I> Loading MEMBCT
[0000.369] I> Slot: 0
[0000.371] I> Binary[6] block-3840 (partition size: 0x60000)
[0000.377] I> Binary name: MEM-BCT-6
[0000.380] I> Size of crypto header is 8192
[0000.384] I> Size of crypto header is 8192
[0000.388] I> BCH of MEM-BCT-6 read from storage
[0000.392] I> MEM-BCT-6 header integrity check is success
[0000.397] I> Binary magic in BCH component 6 is MEM6
[0000.402] I> component binary type is 6
[0000.406] I> MEM-BCT-6 binary is read from storage
[0000.411] I> MEM-BCT-6 binary integrity check is success
[0000.415] C> RAM_CODE 0xc
[0000.420] C> RAM_CODE 0xc
[0000.421] I> Task: Load Page retirement list
[0000.424] I> DRAM ECC PRL is disabled
[0000.428] I> Task: SDRAM params override
[0000.432] I> Before update: MssEncryptGenKeys: 0x20000000, MssEncryptDistKeys: 0x00000000, McDefaultEncr: 0x00000000
[0000.442] I> Post update: MssEncryptGenKeys: 0x2000000f, MssEncryptDistKeys: 0x000f000f, McDefaultEncr: 0x80000100
[0000.452] I> Task: Save mem-bct info
[0000.456] I> Task: Carveout allocate
[0000.459] I> GR carveout will not be allocated
[0000.463] I> RCM blob carveout will not be allocated
[0000.483] I> Task: Enable WDT 5th expiry
[0000.483] I> Re-Enabling WDT
[0000.483] I> Task: I2C register
[0000.483] I> Task: Fuse Dump
[0000.483] I> opt_ucf_cluster_disable = 0x0
[0000.485] I> opt_c2c_disable = 0x0
[0000.488] I> opt_gpc_disable = 0x0
[0000.491] I> opt_tpc_disable = 0x8
[0000.495] I> opt_fbp_disable = 0x0
[0000.498] I> opt_nvdec_disable = 0x0
[0000.501] I> opt_nvenc_disable = 0x0
[0000.504] I> opt_isp_disable = 0x0
[0000.508] I> opt_mgbe_disable = 0x0
[0000.511] I> opt_fsi_disable = 0x0
[0000.514] I> fsi_ram_repair_enable = 0x1
[0000.518] I> opt_mss_disable = 0x0
[0000.521] I> OPT_IGPU_RESERVED = 0x165
[0000.525] C> BOOT_NV_INFO = 0x30f788
[0000.528] I> BOOTROM_PATCH_VERSION = 0x3
[0000.532] I> PSCROM_PATCH_VERSION = 0x7
[0000.536] I> OPT_ADC_CAL_FUSE_REV = 0x4
[0000.539] I> OPT_SW_L1MAINRST_ENABLE = 0x1
[0000.543] I> OPT_EMPD_CALIB_REV = 0x2
[0000.547] I> OPT_EMPD_CALIB = 0x784
[0000.550] I> OPT_CSDC_ENABLE = 0x0
[0000.553] I> OPT_PV_DAC_CTRL_REV = 0x3
[0000.557] I> OPT_PV_BG_CTRL_DAC_OFFSETS_REV = 0x3
[0000.561] I> opt_ECC_en = 0x1
[0000.564] I> SKU_INFO = 0xa0 (PROD)
[0000.568] C> OPT_SAMPLE_TYPE = 0x3
[0000.571] C> opt_subrevision = 0x2
[0000.574] I> opt_lot_code_0 = 0xf503008 (rdl)
[0000.578] I> opt_ft_rev = 0x40
[0000.581] I> opt_fuse_file_version = v55
[0000.585] I> slt_info = 0x3
[0000.588] I> cpu_speedo_calib = 0x88e
[0000.591] I> cpu_ht_iddq_calib = 0x71
[0000.595] I> soc_speedo_calib = 0x893
[0000.598] I> soc_ht_iddq_calib = 0x6f
[0000.602] I> gpu_speedo_calib = 0x883
[0000.605] I> gpu_ht_iddq_calib = 0x16c
[0000.608] I> mss_speedo_calib = 0x87b
[0000.612] I> mss_ht_iddq_calib = 0x1965
[0000.616] I> Task: POD config init
[0000.619] I> Task: Reset FSI
[0000.622] I> Task: Update FSI scratch with fuse data
[0000.626] I> Task: Load and update platform data
[0000.631] I> Sku value zero. Using platform data in MB1 BCT
[0000.636] I> Task: Release membct carveout
[0000.640] I> Task: Pinmux init
[0000.644] I> Task: Prod config init
[0000.647] W> PROD_CONFIG: controller prod table is empty in MB1 BCT.
[0000.653] I> Task: Pad voltage init
[0000.656] I> Task: Prod init
[0000▒
I wonder if you could offer some suggestions?
Looking forward to your reply.
Hi kepts,
Is the issue specific to your custom carrier board?
It seems the similar issue as THOR board design Power on - #3 by KevinFFF, it looks more like the HW related issue, please refer to that thread to check if it could help for your case.
