my device is AGX Xavier 32GB JetPack 4.6,
i use the commands below to install custom kernel (include a custom camera driver) in JetPack 4.6
sudo cp ~/Image /boot/Image -f
sudo cp ~/Image.sig /boot/Image.sig -f
after reboot, nothing is happened, driver is not installed. but it’s works fine in JetPack 4.5.1.
i try to delete the /boot folder and reboot:
sudo rm -rf /boot
and AGX boot normally. that’s weird. it should not boot after i delete the /boot folder.
so, i think the kernel files are moved to somewhere else in JetPack 4.6. that’s why my custom driver can’t install.
please don’t overwrite /boot/Image.sig; if you’re only update kernel image for testing your kernel modifications.
please only update /boot/Image and reboot the system to make the changes take effect.
besides, after you delete /boot/ binaries, the kernel image load via partition, that’s flashed to your target, you may have partition update with the -k options to flash it individually.
