Problem Description:
We have a Xavier 16G eMMC module and we design a carrier board . We Modified the kernel, reborn the kernel to the module, and found that the kernel could not be updated
Operation process:
- Using sdkmanager, version jp4.4dp
- Clone image file- system.img clone- system.img.raw
- Replace / bootloader/ system.img : cp clone- system.img.raw system.img
- Modify the kernel source code (corresponding to version r32.4.2) and compile the kernel
- Copy the generated image and DTB files from the kernel output directory to Linux_ for_ Tegra / kernel / image and Linux_ for_ Tegra/kernel/dtb
- Burn kernel: sudo/ flash.sh -r -K kernel/Image jetson-xavier mmcblk0p1
Other methods tried to update the kernel:
Replace / boot / image (this method fails, the system cannot be started, and cannot enter the desktop system)
None of the above operations can update the kernel.Would you please help us how to do
