Hi All,
I am trying to modify a procedure that worked on L4T R32.2.1 in order to run RT patched kernel. Originally the procedure was run inside a Docker (image sourced from https://medium.com/@r7vme/real-time-kernel-for-nvidia-agx-xavier-b660e107a211) but I am using host PC with ubuntu instead.
Original procedure:
FROM ubuntu:bionic
RUN apt update *
&& apt install -y *
aria2 *
bc *
build-essential *
git-core *
kmod *
lbzip2 *
python *
sudo *
xxd *
&& rm -rf /var/lib/apt/lists/**
Download toolchain for crosscompilation.*
RUN aria2c -x 10 https://developer.nvidia.com/embedded/dlc/l4t-gcc-7-3-1-toolchain-64-bit *
&& tar xf gcc-linaro-7.3.1-2018.05-x86_64_aarch64-linux-gnu.tar.xz *
&& rm -f gcc-linaro-7.3.1-2018.05-x86_64_aarch64-linux-gnu.tar.xz*
Download Jetson drivers and root filesystem.*
RUN aria2c -x 10 *
https://developer.nvidia.com/embedded/dlc/Jetson_Linux_R32.2.1 *
&& aria2c -x 10 *
https://developer.nvidia.com/embedded/dlc/r32-2-1_Release_v1.0/TX2-AGX/Tegra_Linux_Sample-Root-Filesystem_R32.2.1_aarch64.tbz2 *
&& tar xpf Jetson_Linux_R32.2.1_aarch64.tbz2 *
&& cd Linux_for_Tegra/rootfs *
&& tar xpf ../../Tegra_Linux_Sample-Root-Filesystem_R32.2.1_aarch64.tbz2 *
&& rm -f Tegra_Linux_Sample-Root-Filesystem_R32.2.1_aarch64.tbz2 Jetson_Linux_R32.2.1_aarch64.tbz2*
WORKDIR /Linux_for_Tegra*
Download kernel sources.*
RUN ./source_sync.sh -k tegra-l4t-r32.2.1*
l*
ENV CROSS_COMPILE=“/gcc-linaro-7.3.1-2018.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-”*
ENV KERNEL_SRC_DIR=“/Linux_for_Tegra/sources/kernel/kernel-4.9”*
ENV KERNEL_OUT_DIR=“/Linux_for_Tegra/kernel”*
ENV ROOTFS_DIR=“/Linux_for_Tegra/rootfs”*
Apply PREEMPT_RT patches*
RUN cd ${KERNEL_SRC_DIR}/scripts && ./rt-patch.sh apply-patches && cd -*
Compile kernel and install modules.*
RUN cd ${KERNEL_SRC_DIR} *
&& mkdir ${KERNEL_SRC_DIR}/build *
&& make ARCH=arm64 O=${KERNEL_SRC_DIR}/build tegra_defconfig *
&& make ARCH=arm64 O=${KERNEL_SRC_DIR}/build CROSS_COMPILE=${CROSS_COMPILE} -j4*
&& make ARCH=arm64 O=${KERNEL_SRC_DIR}/build INSTALL_MOD_STRIP=1 CROSS_COMPILE=${CROSS_COMPILE} INSTALL_MOD_PATH=${ROOTFS_DIR} modules_install*
Generate image for default kernel (w/o realtime patches) first*
RUN ./apply_binaries.sh*
RUN FAB=400 BOARDID=2888 FUSELEVEL=fuselevel_production BOARDSKU=0001 BOARDREV=H.0 ./build_l4t_bup.sh jetson-xavier mmcblk0p1*
RUN cp bootloader/payloads_t19x/bl_update_payload bootloader/payloads_t19x/bl_update_payload_default*
Copy kernel and modules to final destination.*
RUN tar -C ${ROOTFS_DIR} -cjf ${KERNEL_OUT_DIR}/kernel_supplements.tbz2 lib/modules *
&& cp ${KERNEL_SRC_DIR}/build/arch/arm64/boot/Image ${KERNEL_OUT_DIR}*
Prepare rootfs.*
Generate OTA update image.*
This worked fine with R32.2.1. When I follow all the steps taken by the docker image with updated sources (Tegra186_Linux_R32.4.4_aarch64.tbz2) and filesystem (Tegra_Linux_Sample-Root-Filesystem_R32.4.4_aarch64) I get no build errors. Also when I run nv_update_engine --install with the bl_update_payload in /opt/ota_package it all goes fine but I still get the old kernel after the reboot (nv_update_engine -v confirms that updated slot booted successfully). It seems to me that the bl_update_payload does not contain the updated kernel. Does the kernel image needs to be in some other directory instead of ${KERNEL_OUT_DIR} to be used by ./build_l4t_bup.sh script? Is the bl_update_payload still used to update the kernel image?
Just to be sure here are the steps I am taking:
- tar xpf Tegra186_Linux_R32.4.4_aarch64.tbz2
- cd Linux_for_Tegra/rootfs and tar xpf ../../Tegra_Linux_Sample-Root-Filesystem_R32.4.4_aarch64.tbz2
- ./source_sync.sh -k tegra-l4t-r32.4.4
- ./rt-patch.sh apply-patches in kernel source dir
- mkdir ${KERNEL_SRC_DIR}/build
- make ARCH=arm64 O=${KERNEL_SRC_DIR}/build LOCALVERSION=-tegraRT tegra_defconfig
- make ARCH=arm64 O=${KERNEL_SRC_DIR}/build LOCALVERSION=-tegraRT CROSS_COMPILE=${CROSS_COMPILE} -j12
- make ARCH=arm64 O=${KERNEL_SRC_DIR}/build LOCALVERSION=-tegraRT INSTALL_MOD_STRIP=1 CROSS_COMPILE=${CROSS_COMPILE} INSTALL_MOD_PATH=${ROOTFS_DIR} modules_install
copy Image and modules: - tar -C ${ROOTFS_DIR} -cjf ${KERNEL_OUT_DIR}/kernel_supplements.tbz2 lib/modules
- cp ${KERNEL_SRC_DIR}/build/arch/arm64/boot/Image ${KERNEL_OUT_DIR}
- run ./apply_binaries.sh in Linux_for_Tegra dir
- run FAB=400 BOARDID=2888 FUSELEVEL=fuselevel_production BOARDSKU=0004 BOARDREV=K.0 ./build_l4t_bup.sh jetson-xavier mmcblk0p1
Then i scp payload from Linux_for_Tegra/bootloader/payloads_t19x/bl_update_payload and modules from Linux_for_Tegra/kernel/kernel_supplements.tbz2 to the target board, untar supplements, run update, reboot and get a month old kernel again. Any ideas what needs to be check to make sure I boot the new RT kernel?
Thanks,
Lukas
