Kernel (nvidia-l4t-kernel (5.10.65-tegra-34.1.1-20220516211757)) update fails
Hey,
So was planning to do a full upgrade (r34.1), but due to some dependency issues, I first upgraded the Ubuntu OS from Bionic to Focal.
Secondly I updated the apt sources (coming from r32.6).
deb https://repo.download.nvidia.com/jetson/common r34.1 main
deb https://repo.download.nvidia.com/jetson/t194 r34.1 main
But then it gets stuck configuring the new kernel:
Setting up nvidia-l4t-kernel (5.10.65-tegra-34.1.1-20220516211757) ...
Using the existing boot entry 'primary'
2888-400-0004--1-2-jetson-agx-xavier-devkit-
Starting kernel post-install procedure.
ERROR. Procedure for kernel update FAILED.
Cannot install package. Exiting...
dpkg: error processing package nvidia-l4t-kernel (--configure):
 installed nvidia-l4t-kernel package post-installation script subprocess returned error exit status 1
Errors were encountered while processing:
 nvidia-l4t-kernel
Looking at the postinst script, it fails during:
/usr/sbin/nv_bootloader_payload_updater --forced-part kernel
Log (/opt/ota_package/kernel.log):
Got individual part name: kernel
Got update payload: /opt/ota_package/bl_update_payload
Use fixed smd information for forced update
Tegra User Block Device: /dev/disk/by-partlabel
Tegra Boot Block Device: /dev/mmcblk0boot0
HEADER: MAGIC NVIDIA__BLOB__V2
HEX_VALUE 16909857
BLOB_SIZE 48455176
HEADER_SIZE 48
NUMBER_OF_ELEMENTS 19
HEADER_TYPE 0
UNCOMP_SIZE 48455176
MB1_RATCHET_LV 0
MTS_RATCHET_LV 0
ROLLBACK_FUSE_LV 0
Device TN Spec: 2888-400-0004-L.0-1-2-jetson-agx-xavier-devkit-mmcblk0p1
Device Compatible Spec: 2888-400-0004--1-2-jetson-agx-xavier-devkit-
Get Fuse mode failed. Status: 1
OTA Blob update failed. Status: 1
/usr/sbin/nv_bootloader_payload_updater --forced-part Failed.
/etc/nv_boot_control.conf
TNSPEC 2888-400-0004-L.0-1-2-jetson-agx-xavier-devkit-mmcblk0p1
COMPATIBLE_SPEC 2888-400-0004--1-2-jetson-agx-xavier-devkit-
TEGRA_CHIPID 0x19
TEGRA_OTA_BOOT_DEVICE /dev/mmcblk0boot0
TEGRA_OTA_GPT_DEVICE /dev/mmcblk0boot1
Any idea why this fails?
I would suggest using sdkmanager to update it.
And also suggest wait for J5.0GA r35.1 release about middle of August.
OK, thanks for the response, will try and do that.
