Nv_update_engine update failed
I used FAB=100 BOARDID=3668 FUSELEVEL=fuselevel_production BOARDSKU=0000 ./build_l4t_bup.sh jetson-xavier-nx-devkit internal created ota payload and used nv_update_engine to upgrade, but failed, why is this?
lw@lw:/opt/ota_package$ sudo nv_update_engine -i --payload /opt/ota_package/payloads_t19x/ -v -d -f
Nvidia A/B-Redundancy Update tool Version 2.0
Got payload file: /opt/ota_package/payloads_t19x/
Start running: /usr/sbin/nv_bootloader_payload_updater --forced-bl-update /opt/ota_package/payloads_t19x/
Start running: /opt/nvidia/l4t-bootloader-config/nv-l4t-bootloader-config.sh -c
3668-100—1–jetson-xavier-nx-devkit-
Got update payload: /opt/ota_package/payloads_t19x/
Tegra User Block Device: /dev/disk/by-partlabel
Tegra Boot Block Device: /dev/mtdblock0
Tegra GPT Block Device: /dev/mtdblock0
Get SPI boot device size failed
Publish block device failed
/usr/sbin/nv_bootloader_payload_updater --forced-bl-update Failed.
Forced bootloader update is failed
hello liwang54321,
may I know which JetPack release you’re working with, thanks
jetpack 35.1
hello liwang54321,
just need to confirm your commands to create a BUP image,
for example,$ sudo FAB=100 BOARDID=3668 FUSELEVEL=fuselevel_production BOARDSKU=0001 ./build_l4t_bup.sh jetson-xavier-nx-devkit-emmc mmcblk0p1
after that,
you copy the BUP to target, launching nv_update_engine to update Bootloader on both slots(slot A and slot B) but got failed?
