My device is unable to connent to the Internet so I could not use apt
commands, when I run dpkg -i nvidia-l4t-kernel_5.10.120-tegra-35.4.1-20230801124926_arm64.deb
I got the following message:
Preparing to unpack nvidia-l4t-kernel_5.10.120-tegra-35.4.1-20230801124926_arm64.deb ...
Unpacking nvidia-l4t-kernel (5.10.120--tegra-35.4.1-20230801124926) over (5.10.120-tegra-35.4.1-20230801124926) ...
Setting up nvidia-l4t-kernel (5.10.120-tegra-35.4.1-20230801124926) ...
Using the existing boot entry 'primary'
Warning: Cannot get compatible board name.
3767--0001--1--p3509-a02+p3767-0001-
Info. Active boot storage:: nvme0n1
Info. Legacy mode: false
TNSPEC 3767-300-0001-N.2-1-0-p3509-a02+p3767-0001-
COMPATIBLE_SPEC 3767--0001--1--p3509-a02+p3767-0001-
TEGRA_LEGACY_UPDATE false
TEGRA_BOOT_STORAGE nvme0n1
TEGRA_EMMC_ONLY false
TEGRA_CHIPID 0x23
TEGRA_OTA_BOOT_DEVICE /dev/mtdblock0
TEGRA_OTA_GPT_DEVICE /dev/mtdblock0
Info: Write TegraPlatformCompatSpec with 3767--0001--1--p3509-a02+p3767-0001-.
Starting kernel post-install procedure.
Rootfs AB is not enabled.
ERROR. Procedure for A_kernel update FAILED.
Cannot install package. Exiting...
dpkg: error processing package nvidia-l4t-kernel (--install):
installed nvidia-l4t-kernel package post-installation script subprocess returned error exit status 1
Errors were encountered while processing:
nvidia-l4t-kernel
