I have a Jetson Xavier AGX and tried to upgrade the L4T to a new point release following the instructions found here:
Over-the-Air Update
after issuing the command 'sudo apt upgrade’ I got the following:
Setting up libgstreamer-plugins-base1.0-0:arm64 (1.14.5-0ubuntu1~18.04.3) …
Setting up nvidia-l4t-kernel-dtbs (4.9.201-tegra-32.5.2-20210709090156) …
Setting up libpython3.6-stdlib:arm64 (3.6.9-1~18.04ubuntu1.4) …
Setting up nvidia-l4t-bootloader (32.5.2-20210709090156) …
Warning: Cannot get compatible board name.
2888-400-0004–1-2-rtso-1001-mmcblk0p1
Starting bootloader post-install procedure.
rootfs AB is not enabled.
ERROR. Procedure for bl_update_payload update FAILED.
Cannot install package. Exiting…
dpkg: error processing package nvidia-l4t-bootloader (–configure):
installed nvidia-l4t-bootloader package post-installation script subprocess returned error exit status 1
Setting up chromium-browser (95.0.4638.69-0ubuntu0.18.04.1) …
Setting up gstreamer1.0-plugins-base:arm64 (1.14.5-0ubuntu1~18.04.3) …
Setting up nvidia-l4t-xusb-firmware (32.5.2-20210709090156) …
Starting xusb firmware post-install procedure.
Update xusb firmware completed.
Reboot the target system for changes to take effect.
Setting up libqt5widgets5:arm64 (5.9.5+dfsg-0ubuntu2.6) …
setting up continues with a few more packages and finally I get:
Processing triggers for ca-certificates (20210119~18.04.2) …
Updating certificates in /etc/ssl/certs…
0 added, 0 removed; done.
Running hooks in /etc/ca-certificates/update.d…
done.
Processing triggers for initramfs-tools (0.130ubuntu3.13) …
update-initramfs: Generating /boot/initrd.img-4.9.201-tegra
Warning: couldn’t identify filesystem type for fsck hook, ignoring.
I: The initramfs will attempt to resume from /dev/zram3
I: (UUID=26284415-91dd-4035-86c6-e0b851cdb92f)
I: Set the RESUME variable to override this.
/sbin/ldconfig.real: Warning: ignoring configuration file that cannot be opened: /etc/ld.so.conf.d/aarch64-linux-gnu_EGL.conf: No such file or directory
/sbin/ldconfig.real: Warning: ignoring configuration file that cannot be opened: /etc/ld.so.conf.d/aarch64-linux-gnu_GL.conf: No such file or directory
Processing triggers for nvidia-l4t-kernel (4.9.201-tegra-32.5.2-20210709090156) …
Processing triggers for libc-bin (2.27-3ubuntu1.4) …
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
I tried rebooting and then 'sudo apt upgrade’ once more, but issue remains.
I intent to use the board in a production environment, but now I’m stuck as I don’t know if the installation is corrupted or not.
I tried searching the forums for similar issues, but couldn’t find anything that could help me resolve the issue. Can anyone please advise?
