I have encountered exactly same issue given in link
My device is Xavier Nx Carrier Board. I try to upgrade to Jetpack 5.0.2 from Jetpack 5.0.1 by following given commands in jetpack upgrade documentation. This method is unable to install nvidia-l4t-kernel and nvidia-l4t-bootloader.
Error log:
After this operation, 203 MB of additional disk space will be used. Selecting previously unselected package nvidia-l4t-bootloader.
(Reading database ... 162004 files and directories currently installed.) Preparing to unpack .../nvidia-l4t-bootloader_35.1.0-20220810203728_arm64.deb ... Unpacking nvidia-l4t-bootloader (35.1.0-20220810203728) ... Setting up nvidia-l4t-bootloader (35.1.0-20220810203728) ... 3668-301---1--jetson-xavier-nx-devkit-qspi- Starting bootloader post-install procedure. ERROR. Procedure for bl_only_payload update FAILED.
Cannot install package. Exiting... dpkg: error processing package nvidia-l4t-bootloader (--configure): installed nvidia-l4t-bootloader package post-installation script subprocess returned error exit status 1 Setting up nvidia-l4t-kernel (5.10.104-tegra-35.1.0-20220810203728) ... Using the existing boot entry 'primary' 3668-301---1--jetson-xavier-nx-devkit-qspi- Starting kernel post-install procedure. ERROR. Procedure for kernel update FAILED.
Cannot install package. Exiting... dpkg: error processing package nvidia-l4t-kernel (--configure): installed nvidia-l4t-kernel package post-installation script subprocess returned error exit status 1
dpkg: dependency problems prevent configuration of nvidia-l4t-kernel-headers: nvidia-l4t-kernel-headers depends on nvidia-l4t-kernel (= 5.10.104-tegra-35.1.0-20220810203728); however: Package nvidia-l4t-kernel is not configured yet.
dpkg: error processing package nvidia-l4t-kernel-headers (--configure): dependency problems - leaving unconfigured dpkg: dependency problems prevent configuration of nvidia-l4t-jetson-io: nvidia-l4t-jetson-io depends on nvidia-l4t-kernel (>> 5.10.104-tegra-35.1-0); however: Package nvidia-l4t-kernel is not configured yet. nvidia-l4t-jetson-io depends on nvidia-l4t-kernel (<< 5.10.104-tegra-35.2-0); however: Package nvidia-l4t-kernel is not configured yet.
dpkg: error processing package nvidia-l4t-jetson-io (--configure): dependency problems - leaving unconfigured dpkg: dependency problems prevent configuration of nvidia-l4t-display-kernel: nvidia-l4t-display-kernel depends on nvidia-l4t-kernel (= 5.10.104-tegra-35.1.0-20220810203728); however: Package nvidia-l4t-kernel is not configured yet.
No apport report written because the error message indicates its a followup error from a previous failure. No apport report written because MaxReports is reached already
dpkg: error processing package nvidia-l4t-display-kernel (--configure): dependency problems - leaving unconfigured dpkg: dependency problems prevent configuration of nvidia-l4t-kernel-dtbs: nvidia-l4t-kernel-dtbs depends on nvidia-l4t-kernel (= 5.10.104-tegra-35.1.0-20220810203728); however: Package nvidia-l4t-kernel is not configured yet.
dpkg: error processing package nvidia-l4t-kernel-dtbs (--configure): dependency problems - leaving unconfigured No apport report written because MaxReports is reached already No apport report written because MaxReports is reached already Errors were encountered while processing: nvidia-l4t-bootloader nvidia-l4t-kernel nvidia-l4t-kernel-headers nvidia-l4t-jetson-io nvidia-l4t-display-kernel nvidia-l4t-kernel-dtbs E: Sub-process /usr/bin/dpkg returned an error code (1)
