Kernel upgrade error
The display shows black screen, which is probably due to kernel, when I try to update kernel, this error happens
Setting up nvidia-l4t-kernel (5.10.192-tegra-35.5.0-20240613202628) …
Using the existing boot entry ‘primary’
Warning: Cannot get compatible board name.
3767–0001–1–recomputer-orin-
Info. Installing mtdblock.
Info. Active boot storage: nvme0n1
Info. Legacy mode: false
sed: cannot rename /etc/sedoiVuRK: Operation not permitted
sed: cannot rename /etc/sedTrzpKQ: Operation not permitted
TNSPEC 3767-300-0001-R.1-1-0-recomputer-orin-
COMPATIBLE_SPEC 3767–0001–1–recomputer-orin-
TEGRA_LEGACY_UPDATE true
TEGRA_BOOT_STORAGE nvme0n1
TEGRA_EMMC_ONLY false
TEGRA_CHIPID 0x23
TEGRA_OTA_BOOT_DEVICE /dev/mtdblock0
TEGRA_OTA_GPT_DEVICE /dev/mtdblock0
ROOTFS_AB=true
Info: Write TegraPlatformCompatSpec with 3767–0001–1–recomputer-orin-.
Starting kernel post-install procedure.
Starting legacy update procedure.
ERROR. Procedure for A_kernel update FAILED.
Cannot install package. Exiting…
dpkg: error processing package nvidia-l4t-kernel (–configure):
installed nvidia-l4t-kernel package post-installation script subprocess returned error exit status 1
Errors were encountered while processing:
nvidia-l4t-kernel
You cannot do this on a custom board. The nvidia-l4t-kernel is only for NV devkit to run.
