Info: Write TegraPlatformCompatSpec with 3767-000-0000–1–recomputer-orin-.
Starting kernel post-install procedure.
Rootfs AB is not enabled.
ERROR. Procedure for A_kernel update FAILED.
Cannot install package. Exiting…
dpkg: error processing package nvidia-l4t-kernel (–configure):
installed nvidia-l4t-kernel package post-installation script subprocess returned error exit status 1
dpkg: dependency problems prevent configuration of nvidia-l4t-kernel-headers:
nvidia-l4t-kernel-headers depends on nvidia-l4t-kernel (= 5.10.192-tegra-35.5.0-20240613202628); however:
Package nvidia-l4t-kernel is not configured yet.
dpkg: error processing package nvidia-l4t-kernel-headers (–configure):
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of nvidia-l4t-display-kernel:
nvidia-l4t-display-kernel depends on nvidia-l4t-kernel (= 5.10.192-tegra-35.5.0-20240613202628); however:
dpkg: error processing package nvidia-l4t-display-kernel (–configure):
No apport report written because the error message indicates its a followup error from a previous failure.
dpkg: dependency problems prevent configuration of nvidia-l4t-kernel-dtbs:
nvidia-l4t-kernel-dtbs depends on nvidia-l4t-kernel (= 5.10.192-tegra-35.5.0-20240613202628); however:
dpkg: error processing package nvidia-l4t-kernel-dtbs (–configure):
No apport report written because MaxReports is reached already
Errors were encountered while processing:
nvidia-l4t-kernel
E: Sub-process /usr/bin/dpkg returned an error code (1)
When I’m trying to upgrade the system I’m recieving this error. How can I resolve this?
