Has anyone experienced bellow issue when running sudo apt-get update/upgrade on the Nvidia Jetson Xavier NX board??Does anyone know how to solve it? The jetpack version is 5.1 35.2.1.
Package nvidia-l4t-kernel is not configured yet.
Errors were encountered while processing:
nvidia-l4t-bootloader
nvidia-l4t-kernel
nvidia-l4t-kernel-headers
nvidia-l4t-jetson-io
nvidia-l4t-display-kernel
nvidia-l4t-kernel-dtbs
Below more log messages. My initial intention is to run Kubernetes k3s on the Jetson cluster. I suspect there is an issue with nvidia docker functionality, since i can not see gpu inside of cluster.
Use 'sudo apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
6 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] y
Setting up nvidia-l4t-bootloader (35.2.1-20230124153320) ...
3668-301---1--jetson-xavier-nx-devkit-qspi-
Info. Installing mtdblock.
Info. Active boot storage: nvme0n1
Info. Legacy mode: true
INFO. Dump nv_boot_control.conf:
TNSPEC 3668-301-0003-B.0-1-2-jetson-xavier-nx-devkit-qspi-
COMPATIBLE_SPEC 3668-301---1--jetson-xavier-nx-devkit-qspi-
TEGRA_LEGACY_UPDATE true
TEGRA_BOOT_STORAGE nvme0n1
TEGRA_EMMC_ONLY false
TEGRA_CHIPID 0x19
TEGRA_OTA_BOOT_DEVICE /dev/mtdblock0
TEGRA_OTA_GPT_DEVICE /dev/mtdblock0
Starting bootloader post-install procedure.
INFO. Installing mtdblock.
Starting legacy update procedure.
ERROR. Procedure for bl_only_payload update FAILED.
Cannot install package. Exiting...
dpkg: error processing package nvidia-l4t-bootloader (--configure):
installed nvidia-l4t-bootloader package post-installation script subprocess returned error exit status 1
Setting up nvidia-l4t-kernel (5.10.104-tegra-35.2.1-20230124153320) ...
Using the existing boot entry 'primary'
Starting kernel post-install procedure.
ERROR. Procedure for kernel update FAILED.
dpkg: error processing package nvidia-l4t-kernel (--configure):
installed nvidia-l4t-kernel package post-installation script subprocess returned error exit status 1
dpkg: dependency problems prevent configuration of nvidia-l4t-kernel-headers:
nvidia-l4t-kernel-headers depends on nvidia-l4t-kernel (= 5.10.104-tegra-35.2.1-20230124153320); however:
dpkg: error processing package nvidia-l4t-kernel-headers (--configure):
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of nvidia-l4t-jetson-io:
nvidia-l4t-jetson-io depends on nvidia-l4t-kernel (>> 5.10.104-tegra-35.2-0); however:
nvidia-l4t-jetson-io depends on nvidia-l4t-kernel (<< 5.10.104-tegra-35.3-0); however:
dpkg: error processing package nvidia-l4t-jetson-io (--configure):
dpkg: dependency problems prevent configuration of nvidia-l4t-display-kernel:
nvidia-l4t-display-kernel depends on nvidia-l4t-kernel (= 5.10.104-tegra-35.2.1-20230124153320); however:
dpkg: error processing package nvidia-l4t-display-kernel (--configure):
dpkg: dependency problems prevent configuration of nvidia-l4t-kernel-dtbs:
No apport report written because the error message indicates its a followup error from a previous failure.
No apport report written because MaxReports is reached already
nvidia-l4t-kernel-dtbs depends on nvidia-l4t-kernel (= 5.10.104-tegra-35.2.1-20230124153320); however:
dpkg: error processing package nvidia-l4t-kernel-dtbs (--configure):
nvidia-l4t-kernel
E: Sub-process /usr/bin/dpkg returned an error code (1)
Hi @AastaLLL, thanks for your reply. Potentially, I have encountered two separate issues. It seems that k3s utilizes containerd as the default container runtime, which was deployed automatically by Ansible. However, I require the Docker runtime instead. I can not solve the issue with the “Errors were encountered while processing:”
