Failed to upgrade all packages
Initialized jetbot 0.4.3, and did a thorough upgrade, but failed with the following messages:
Setting up nvidia-l4t-bootloader (32.5.2-20210709090126) ...
3448-300-0003--1--jetson-nano-2gb-devkit-mmcblk0p1
Starting bootloader post-install procedure.
ERROR. Procedure for bootloader update FAILED.
Cannot install package. Exiting...
dpkg: error processing package nvidia-l4t-bootloader (--configure):
 installed nvidia-l4t-bootloader package post-installation script subprocess returned error exit status 1
Setting up nvidia-l4t-xusb-firmware (32.5.2-20210709090126) ...
Starting xusb firmware post-install procedure.
ERROR. Procedure for xusb firmware update FAILED.
dpkg: error processing package nvidia-l4t-xusb-firmware (--configure):
 installed nvidia-l4t-xusb-firmware package post-installation script subprocess returned error exit status 1
dpkg: dependency problems prevent configuration of nvidia-l4t-initrd:
 nvidia-l4t-initrd depends on nvidia-l4t-xusb-firmware (= 32.5.2-20210709090126); however:
  Package nvidia-l4t-xusb-firmware is not configured yet.
dpkg: error processing package nvidia-l4t-initrd (--configure):
 dependency problems - leaving unconfigured
Processing triggers for desktop-file-utils (0.23-1ubuntu3.18.04.2) ...
No apport report written because the error message indicates its a followup error from a previous failure.
        Processing triggers for initramfs-tools (0.130ubuntu3.13) ...
update-initramfs: Generating /boot/initrd.img-4.9.201-tegra
Warning: couldn't identify filesystem type for fsck hook, ignoring.
I: The initramfs will attempt to resume from /dev/zram3
I: (UUID=18f16a4a-4168-41cd-93a0-cdfc5aa629fc)
I: Set the RESUME variable to override this.
/sbin/ldconfig.real: Warning: ignoring configuration file that cannot be opened: /etc/ld.so.conf.d/aarch64-linux-gnu_EGL.conf: No such file or directory
/sbin/ldconfig.real: Warning: ignoring configuration file that cannot be opened: /etc/ld.so.conf.d/aarch64-linux-gnu_GL.conf: No such file or directory
Processing triggers for bamfdaemon (0.5.3+18.04.20180207.2-0ubuntu1) ...
Rebuilding /usr/share/applications/bamf-2.index...
Processing triggers for libc-bin (2.27-3ubuntu1.6) ...
Processing triggers for man-db (2.8.3-2ubuntu0.1) ...
Processing triggers for gnome-menus (3.13.3-11ubuntu1.1) ...
Processing triggers for dbus (1.12.2-1ubuntu1.4) ...
Processing triggers for hicolor-icon-theme (0.17-2) ...
Processing triggers for mime-support (3.60ubuntu1) ...
Errors were encountered while processing:
 nvidia-l4t-initrd
E: Sub-process /usr/bin/dpkg returned an error code (1)
Any suggestions?
Please check those JetBot related topics on the JetBot GitHub Discussions to see if can find the reference.
