Sudo apt-get upgrade returning with error
Device : Jetson Nano 4GB
Jetpack: 4.4.1
Hi
I have download the archived version of jetson nano which had jetpack 4.4.1, and burned the SD card, after that did
sudo apt-get update
which worked with no issue but then doing
sudo apt-get upgrade
gives this error:
Errors were encountered while processing:
nvidia-l4t-bootloader
E: Sub-process /usr/bin/dpkg returned an error code (1)
Even tried the image with jetpack 4.4 but same issue.
Tried burning the same image multiple times but still same.
Downloaded the archive images from here :JetPack Archive | NVIDIA Developer
hello priyanshthakore,
may I know your results to displays a list of new and upgradable packages.
for example, $ apt list --upgradable
Running that command this is the result i get nothing else.
Listing… Done
so all packages were already updated?
please compare the md5sums within dpkg, for example, $ cat /var/lib/dpkg/info/nvidia-l4t-bootloader.md5sums
thanks
This is the full output of sudo apt-get upgrade
$sudo apt-get upgrade
Reading package lists… Done
Building dependency tree
Reading state information… Done
Calculating upgrade… Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
1 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] Y
Setting up nvidia-l4t-bootloader (32.4.4-20201027211359) …
3448-300—1–jetson-nano-qspi-sd-mmcblk0p1
Starting bootloader post-install procedure.
ERROR. Procedure for bootloader update FAILED.
Cannot install package. Exiting…
dpkg: error processing package nvidia-l4t-bootloader (–configure):
installed nvidia-l4t-bootloader package post-installation script subprocess returned error exit status 1
This are the output of checksum, how to check these as in upgrade it is not showing
fee284d867934e0e47c97068c128afff opt/ota_package/t21x/bl_update_payload
e39c97b561b8774e33bdaaf0ba7ab44e usr/share/doc/nvidia-l4t-bootloader/LICENSE.bl_update_payload.gz
507acbd9e9cb6b0118435c4c260cf94a usr/share/doc/nvidia-l4t-bootloader/changelog.Debian.gz
7e975f9aab4d0ed5db5a36433ca6647c usr/share/doc/nvidia-l4t-bootloader/copyright
All packages seems to be upgraded but just this once returns with and error, will removing it affect functioning of jetson ? through
sudo apt-get --force-yes remove nvidia-l4t-bootloader
sorry, you may simply use this command, $ dpkg -l | grep bootloader to check the package version.
please also gather logs for reference,
i.e. $ cat /opt/ota_package/bl_update_payload.log
could you please also check the TNSPEC as following,
i.e. $ cat /etc/nv_boot_control.conf
thanks
please check this, thanks
Hi @JerryChang , I have the exact same issue as @priyanshthakore for jetpack 4.4.1 as well.
When i tried
sudo i2cdump -f -y 2 0x50 @prlawrence
the module part i have is 699-13448-0000-400, which is not >= 402 as mentioned in the link you attached, which suggests that my module is not using the new QSPI-NOR part. but yet I am experiencing this bootloader problem.
Hi ONGC0091,
Please help to open a new topic for your issue. Thanks
