Hello
Since a while ago updating the bootloader from ppa to different versions (for example 32.4 to 32.5 , from 32.5 to 32.6 and from 32.6 to 34.7) causes will an error in the script post-installation script subprocess returned error exit status 1
Setting up nvidia-l4t-bootloader (32.7.1-20220219090432) ...
3448-300---1--jetson-nano-qspi-sd-mmcblk0p1
Starting bootloader post-install procedure.
ERROR. Procedure for bootloader update FAILED.
Cannot install package. Exiting...
dpkg: error processing package nvidia-l4t-bootloader (--configure):
installed nvidia-l4t-bootloader package post-installation script subprocess returned error exit status 1
Processing triggers for libc-bin (2.27-3ubuntu1.3) ...
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
Apparently it is related to the information that dpkg saves and it conflicts in the installation
So wee needed move /var/lib/info/ and create new /var/lib/dpkg/info
sudo mv /var/lib/dpkg/info/ /var/lib/dpkg/backup/
sudo mkdir /var/lib/dpkg/info/
Next update repos and force install .
sudo apt-get update
sudo apt-get -f install
Move the new structure dpkg/info to old info
sudo mv /var/lib/dpkg/info/* /var/lib/dpkg/backup/
Remove the new dpkg structure folder and back the old
sudo rm -rf /var/lib/dpkg/info
sudo mv /var/lib/dpkg/backup/ /var/lib/dpkg/info/
If this is not done, it will complain in the script and its installation will always fail.
It’s a “hackly” way without having to flash again.
Regards
Carlos.
