I’ve modified the dts and used on our carrier board
After building the dts and complete flashing to the AGX, the dtb seems not apply
And the reason could be the /boot/extlinux/extlinux.conf has set the /boot/dtb/kernel_tegra194-p2888-0001-p2822-0000.dtb for default
So I copy the L4T/bootloader/kernel_tegra194-p2888-0001-p2822-0000.dtb on my host, and overwrite the /boot/dtb/kernel_tegra194-p2888-0001-p2822-0000.dtb on the target
But it still not work
Then I tried the tegra194-p2888-0001-p2822-0000.dtb under the bootloader to overwrite the /boot/dtb/kernel_tegra194-p2888-0001-p2822-0000.dtb on the target
it works
My question is what are these dtb files means?
Most of them are the same certified by the command “diff”
What’s the file in bootloader correspond to the dtb under /boot/dtb in target
How the tegra194-p2888-0001-p2822-0000.dtb appears under bootloader?
Why it is different from the kernel_tegra194-p2888-0001-p2822-0000.dtb?
I didn’t encounter this situation when I use AGX Xavier on J4.6.2
