Question: Update [kerel-dtb] is not supported, what that means? (Solved)
Try to build kernel, and update dtb.
I can build it, flash kernel into Xavier. But when flash dtb, seems system is not happy.
I used the same method on TX2 before, it works. Any thing changed in Xavier?
gtang@ws4:~/jetpack4/Xavier/Linux_for_Tegra$ sudo ./flash.sh -r -k kerel-dtb -d rootfs/boot/tegra194-p2888-0001-p2822-0000.dtb jetson-xavier mmcblk0p1
Existing tbcfile(/home/gtang/jetpack4/Xavier/Linux_for_Tegra/bootloader/cboot_t194.bin) reused.
copying tbcdtbfile(/home/gtang/jetpack4/Xavier/Linux_for_Tegra/kernel/dtb/tegra194-p2888-0001-p2822-0000.dtb)… done.
copying cfgfile(/home/gtang/jetpack4/Xavier/Linux_for_Tegra/bootloader/t186ref/cfg/flash_t194_sdmmc.xml) to flash.xml… done.
Existing flasher(/home/gtang/jetpack4/Xavier/Linux_for_Tegra/bootloader/nvtboot_recovery_cpu_t194.bin) reused.
Existing flashapp(/home/gtang/jetpack4/Xavier/Linux_for_Tegra/bootloader/tegraflash.py) reused.
*** Update [kerel-dtb] is not supported. ***
Hi @gue.tang
You have a typo in your command :
should be:
sudo ./flash.sh -r -k kernel-dtb
hello guo.tang,
Spawn32 is correct, you had a typo of your command,
in addition, you may also refer to flash_t194_sdmmc.xml for partition names to have more details.
thanks
