When I use this command to flash, there will be errors.
$ sudo ./flash.sh -r -k jetson-xavier mmcblk0p1
Reusing existing system.img…
done.
Existing tbcfile(/home/lion/nvidia/xavier16G-jp4.4dp/JetPack_4.4_DP_Linux_DP_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/cboot_t194.bin) reused.
copying tbcdtbfile(/home/lion/nvidia/xavier16G-jp4.4dp/JetPack_4.4_DP_Linux_DP_JETSON_AGX_XAVIER/Linux_for_Tegra/kernel/dtb/tegra194-p2888-0001-p2822-0000.dtb)… done.
copying cfgfile(/home/lion/nvidia/xavier16G-jp4.4dp/JetPack_4.4_DP_Linux_DP_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/t186ref/cfg/flash_t194_sdmmc.xml) to flash.xml… done.
Existing flasher(/home/lion/nvidia/xavier16G-jp4.4dp/JetPack_4.4_DP_Linux_DP_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/nvtboot_recovery_cpu_t194.bin) reused.
Existing flashapp(/home/lion/nvidia/xavier16G-jp4.4dp/JetPack_4.4_DP_Linux_DP_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/tegraflash.py) reused.
*** Update [jetson-xavier] is not supported. ***
flash-error.log (14.9 KB)
