An error occurs when I set the can0 baudrate.
Configuration commands:
[ set bitrate 500k ]
sudo ip link set can0 type can bitrate 500000
error log:
[ 937.136829] mttcan c310000.mttcan can0: bitrate error 0.2%
If the configuration is less than 500k, there will be no this problem.
The version we are using is Jetson Linux 35.2.1.
Developer Kit Carrier Board is AGX Xavier.
Hi auth-root,
Please refer to the following thread for this issue.
Can bitrate error 0.2% - #4 by shgarg
Controller Area Network (CAN) — Jetson Linux Developer Guide documentation (nvidia.com)
1. Configure parent clock for CAN
# echo pll_c > /sys/kernel/debug/bpmp/debug/clk/can1/parent
# cat /sys/kernel/debug/bpmp/debug/clk/can1/parent
# cat /sys/kernel/debug/bpmp/debug/clk/can1/rate
2. Reload mttcan driver
# rmmod mttcan
# modprobe mttcan
3. setup can0 again to verify
$ sudo ip link set can0 type can bitrate 500000
When I follow the Developer Guide documentation .
dtb to dts error, I used Agx xavier industrial core.
ubuntu:~/JetPack_5.1.1_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/t186ref$ dtc -I dtb -O dts tegra194-a02-bpmp-p2888-0008-b01-jaxi.dtb > tegra194-a02-bpmp-p2888-0008-b01-jaxi.dts
FATAL ERROR: EOF reading DT blob magic number
I found the reason, I will continue to follow the documentation and reply later.
I followthe Developer Guide documentation , the rate can reach 5Mbps, thank you!
system
Closed
December 15, 2023, 1:38am
9
