Hi
I’ve got a SICK IMU which I want to connect via CAN (D-SUB) to the NVIDIA Jetson AGX Xavier.
I’ve used modprobe for can, can-dev, can-raw and mttcan. Then I set up with the bitrate of the IMU und activate can0.
But if I use candump/cansniffer I don’t get any data.
To test the IMU I used a PEAK USB adapter and pcanview. It worked, when I set the right CAN clock to 2000000.
I’ve read that the Jetson has set 500000, and I tried to change:
https://docs.nvidia.com/jetson/l4t/index.html#page/Tegra%20Linux%20Driver%20Package%20Development%20Guide/hw_setup_jetson_can.html#
But I can’t find where to change.
hello gianluca.podann,
you may enable the CAN and configure the CAN interface settings.
for example,
$ ip link set can0 type can bitrate 500000 dbitrate 2000000 berr-reporting on fd on
$ ip link set up can0
thx for help.
I enabled CAN and used your example with my settings, but it doesn’t work.
Does dbitrate mean the clockrate?
there’s some known issue to communicate with other devices.
could you please have a try to configure bitrate artificially high (i.e. 3-Mbps setting for 1-Mbps desired) for testing,
it’s bitrate configurations for the dsample-point. it used by CAN_FD interface type.
thanks
With bitrate 3000000 I get: Invalid argument
Please check following relevant sections from hw_setup_jetson_can document.
Changing the CAN parent clock on T194 platforms
Changing the CAN Clock Rate
