I was trying to configure ai_nvr using DeepStream 7.1 and YOLOv8 with multiple streams. I followed the guide you suggested, but I wasn’t able to complete it because it failed when trying to build deepstream_test5 due to missing dependencies. I tried fixing it by installing the dependencies, but I couldn’t find a solution related to cuda_runtime_api.h.
Additionally, I noticed that l4t-repo.nvidia.com:80 doesn’t work every time I try to install something with apt.
I then repeated the process using the “deepstream:7.1-triton-multiarch” image, and it built successfully.
So, my question is: Do we need to copy the yolov8s-files folder into the Triton container from the public container, or is there a better way? Maybe I’m missing something.
After editing the deepstream_app.c when I did make the deepstream-test5 I got:
root@ubuntu:/opt/nvidia/deepstream/deepstream-7.1/sources/apps/sample_apps/deepstream-test5# export CUDA_VER=12.6
root@ubuntu:/opt/nvidia/deepstream/deepstream-7.1/sources/apps/sample_apps/deepstream-test5# make
Package gstreamer-1.0 was not found in the pkg-config search path.
Perhaps you should add the directory containing gstreamer-1.0.pc' to the PKG_CONFIG_PATH environment variable No package 'gstreamer-1.0' found Package gstreamer-video-1.0 was not found in the pkg-config search path. Perhaps you should add the directory containing gstreamer-video-1.0.pc’
No package ‘gstreamer-video-1.0’ found
Package json-glib-1.0 was not found in the pkg-config search path.
Perhaps you should add the directory containing json-glib-1.0.pc' to the PKG_CONFIG_PATH environment variable No package 'json-glib-1.0' found Package gstreamer-1.0 was not found in the pkg-config search path. Perhaps you should add the directory containing gstreamer-1.0.pc’
No package ‘gstreamer-1.0’ found
Perhaps you should add the directory containing gstreamer-video-1.0.pc' to the PKG_CONFIG_PATH environment variable No package 'gstreamer-video-1.0' found Package json-glib-1.0 was not found in the pkg-config search path. Perhaps you should add the directory containing json-glib-1.0.pc’
No package ‘json-glib-1.0’ found
cc -c -o deepstream_test5_app_main.o -DPLATFORM_TEGRA -I…/…/apps-common/includes -I…/…/…/includes -I…/deepstream-app/ -DDS_VERSION_MINOR=0 -DDS_VERSION_MAJOR=5 -I /usr/local/cuda-12.6/include deepstream_test5_app_main.c
deepstream_test5_app_main.c:13:10: fatal error: gst/gst.h: No such file or directory
13 | include <gst/gst.h>
compilation terminated.
make: *** [Makefile:61: deepstream_test5_app_main.o] Error 1
So I’ve tried to solve the problem by installing the recommended dependencies following this steps:
I’ve tried to resolve manually using the packages from here Index but with no success because lacks of dependencies every time I’ve tried to install a new package related with cuda.
FROM nvcr.io/nvidia/deepstream:7.1-triton-multiarch
# Variables de entorno
ENV NVIDIA_VISIBLE_DEVICES=all
ENV NVIDIA_DRIVER_CAPABILITIES=compute,utility,video
# Instalar dependencias adicionales necesarias
RUN apt-get update && apt-get install -y \
vim \
build-essential \
tar \
&& apt-get clean
# Copiar y descomprimir los archivos necesarios en la raíz del contenedor
COPY config/deepstream/yolov8s/yolov8s-files.tar /
COPY config/deepstream/yolov8s/tmp99.tar /
RUN tar -xvf /yolov8s-files.tar -C / && \
tar -xvf /tmp99.tar -C / && \
rm /yolov8s-files.tar /tmp99.tar
# Modificar el archivo deepstream_app.c
RUN sed -i '1328,1333s/^/\/\/ /' \
/opt/nvidia/deepstream/deepstream-7.1/sources/apps/sample_apps/deepstream-app/deepstream_app.c
# Compilar deepstream_test5
ENV CUDA_VER=12.6
RUN cd /opt/nvidia/deepstream/deepstream-7.1/sources/apps/sample_apps/deepstream-test5 && \
make
# Establecer el punto de entrada del contenedor (opcional, dependerá del uso final)
CMD ["/bin/bash"]
Furthermore, I found out some interesting things I would like to comment.
Using default config_infer_primary_yoloV8.txt after editing the max-batch-size on [source-list] section on the yolov8s-ds-config_nx16.txt I’ve very low FPS with 2 sources from 25fps (1 source with everything on default settings) to 15fps. I’ve also noticed that the engine file was rebuilt.
NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2201> [UID = 1]: deserialized backend context :/yolov8s-files/yolov8s_DAT_noqdq_DLA.engine failed to match config params, trying rebuild
0:00:01.804621792 e[32m 19e[00m 0xaaaab9ab0ca0 e[36mINFO e[00m e[00m nvinfer gstnvinfer.cpp:684:gst_nvinfer_logger:<primary_gie>e[00m NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:2106> [UID = 1]: Trying to create engine from model files
WARNING: [TRT]: Using an engine plan file across different models of devices is not recommended and is likely to affect performance or even cause errors.
Active sources : 2
Fri Jan 3 12:33:30 2025
**PERF:
LAVALLE[fe6fee95-ecf8-42a3-b80c-d0830d443b3f] 15.85 (9.79) CORRIENTES[4e159252-81d7-427e-9c60-48878aa7ae3c] 15.85 (9.34)
I’ve solved this by editing the config_infer_primary_yoloV8.txt with
network-mode from 2 to 1, that is, from FP16 to INT8
enable-dla from 1 to 0.
Active sources : 2
Thu Jan 2 19:34:10 2025
**PERF:
LAVALLE[fe6fee95-ecf8-42a3-b80c-d0830d443b3f] 24.87 (21.92) CORRIENTES[4e159252-81d7-427e-9c60-48878aa7ae3c] 25.07 (22.27)
What it gets my attention is that DLA0c is working and the engine model stop rebuilding, and I don’t really know why.
However, I sorted out with the triton-multiarch container image but the result were poor:
My suspicion was that the problem due to the fact that the engine file wasn’t used but rebuilt, that, so I did this:
And the engine model was correctly loaded (STEP 7 log.txt file):
0:00:02.008779534 e[36m 35e[00m 0xaaab13df6a70 e[36mINFO e[00m e[00m nvinfer gstnvinfer.cpp:684:gst_nvinfer_logger:<primary_gie>e[00m NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:2092> [UID = 1]: deserialized trt engine from :/yolov8s-files/yolov8s_DAT_noqdq_DLA.engine
0:00:02.008846864 e[36m 35e[00m 0xaaab13df6a70 e[36mINFO e[00m e[00m nvinfer gstnvinfer.cpp:684:gst_nvinfer_logger:<primary_gie>e[00m NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2195> [UID = 1]: Use deserialized engine model: /yolov8s-files/yolov8s_DAT_noqdq_DLA.engine
0:00:02.039590710 e[36m 35e[00m 0xaaab13df6a70 e[36mINFO e[00m e[00m nvinfer gstnvinfer_impl.cpp:343:notifyLoadModelStatus:<primary_gie>e[00m [UID 1]: Load new model:/ds-config-files/yolov8s/config_infer_primary_yoloV8.txt sucessfully
I checked out that the dla 0 it’s active because the engine model was created with dla. However, it is mandatory to edit the file config_infer_primary_yoloV8.txt and change network-mode from 2 to 1, that is, from FP16 to INT8 to load the model correctly.
If you need generate TensorRT engine, please use below command line in the JPS 2.0 deepstream docker container:
$ cd /yolov8s-files/
$ cp yolov8s_DAT_noqdq_DLA.engine yolov8s_DAT_noqdq_DLA.engine-bak
$ trtexec --onnx=yolov8s_DAT_noqdq.onnx --fp16 --int8 --verbose --calib=yolov8s_DAT_precision_config_calib.cache --precisionConstraints=obey --layerPrecisions=Split_36:fp16,Reshape_37:fp16,Transpose_38:fp16,Softmax_39:fp16,Conv_41:fp16,Sub_64:fp16,Concat_65:fp16,Mul_67:fp16,Sigmoid_68:fp16,Concat_69:fp16 --saveEngine=yolov8s_DAT_noqdq_DLA.engine --useDLACore=0 --allowGPUFallback
You can either do everything on the last container image, getting the yolov8s-files from the first image, or copy the deepstream-test5 binary into the public.
Edit the file config_infer_primary_yoloV8.txt and change network-mode from 2 to 1, that is, from FP16 to INT8 to load the model correctly.
