• Hardware Platform (Jetson / GPU):jetson orin nano • DeepStream Version:7.1 • JetPack Version (valid for Jetson only):6.1 • TensorRT Version:10.3 • NVIDIA GPU Driver Version (valid for GPU only) • Issue Type( questions, new requirements, bugs) • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) • Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description)
You may see “compose_agx_yolov8s.yaml” in the JPS “package ai_nvr-2.0.1.tar.gz”, you can refer to the “compose_agx_yolov8s.yaml” to modify the “compose_nano.yaml” to support yolov8s
Orin Nano haven’t DLA: NVIDIA Jetson AGX Orin . JPS YOLOv8 will use DLA for inference. So you need make your trained yolov8 run with deepstream app on Orin Nano, then port it to JPS AI NVR. Or use peoplenet on Orin Nano with JPS default release.
