Ainvr, deepstream 7 not generating yolov8s files
I’m trying to run deepstream 7 in ainvr app with yolov8s (the one provided by default), i’ve already been able to run it with peoplenet and it worked without issues, but it’s not working with yolov8s.
I run the app using this command:
sh -c 'deepstream-test5-app  -c /ds-config-files/yolov8s/yolov8s-ds-config_agx.txt 2>&1 | grep --line-buffered . | tee -a /log/deepstream.log'
the container starts but then fails with the following error logs:
it is not creating any engine file.
• Hardware Platform Jetson AGX
• DeepStream 7
• JetPack 6
Note: I’m using the yolov8s-ds-config_agx.txt provided with ainvr deepstream app.
from the log, it is because onnx model path is not set. please refer to this code.
Have you followed the steps in Generate Traffic Insights Using YOLOv8 and NVIDIA JetPack 6.0 | NVIDIA Technical Blog?
Please follow this guide to generate YOLOv8 engine before deploy AI NVR with YOLOV8: DeepStream Perception — Metropolis on Jetson documentation 0.1.0 documentation.
