AINVR Deepstream dropping source after a while on jetson orin nx
• Jetson Orin NX
• DeepStream 7
• JetPack Version 6 36.3
I have deployed ainvr app with deepstream 7, and i’m using nvstreamer to stream videos, the problem is that the source is added to deepstream and drops after a while. i have to restart VST and Deepstream to add the sources again
The configuration i’m using for deepstream :
yolov8s-ds-config_nx16.txt (5.2 KB)
Move to JPS forum.
Can you share the log of deepstream container: docker logs deepstream?
sure, here’s the logs:
sdr-nx-7d67db6f65-24rrn_deepstream-nx-13_25 10_21_2024 UTC-13_42 10_21_2024 UTC.log (261.0 KB)
Can you share where you see the source dropping from you shared log?
In the logs you can see that i 1 source, then it suddenly became 0, there’s no log showing that something happened that made the source drop, except maybe “stream format not found, dropping the frame” ??, here’s a snapshot of the logs where the sources drop:
The log show you remove stream with REST API and add one video stream with REST API. You can check the **PERF: log to decide how many source in DeepStream.
