Amd ryzen 5 nvidea gtx 1050, ubuntu 20.04, no read the nvidea?
Hello, I have had many problems with the controller. When I connect an external screen it does not recognize it, I think it is due to a problem with the drivers, I have the 470 driver installed, but when I open it, only an empty white window appears. Someone could help me?
result of nvidia-bug-report.log
https://pastebin.ubuntu.com/p/XpNBSMt2Cr/
$ nvidia-settings
ERROR: NVIDIA driver is not loaded
ERROR: Unable to load info from any available system
(nvidia-settings:9020): GLib-GObject-CRITICAL **: 00:35:55.498: g_object_unref: assertion ‘G_IS_OBJECT (object)’ failed
** Message: 00:35:55.503: PRIME: No offloading required. Abort
** Message: 00:35:55.503: PRIME: is it supported? no
You have an incompatible kernel installed so the nvidia driver doesn’t compile. Please return to the stock hwe kernel 5.13.
Thanks, it already detects the secondary screen, but not the main one, do you know what it can be?
New result of nvidia-bug-report.log
https://pastebin.ubuntu.com/p/JnnZWnnWjQ/
Please delete /etc/X11/xorg.conf
Thank you very much, that solved everything!
