I am using the Jetson NX platform,and with Jetpack 4.4.1.
As shown in the following figure, I can get h264-data/yuv-data 25fps in the appsink/fakesink by using capture single sensor, no matter how many app-bin are followed by tee.
But after add a same pipeline to capture another sensor, I can get 25fps from the appsink/fakesink with 2 app-bins;I can get only 21fps from the appsink/fakesink with 3 app-bins;and get only 17fps with 4app-bin. As app-bin and queue increase, the number of captured frames decreases.
I had confirmed that Queue didn’t emit the signal which name “OVERRUN” .And in appsink/fakesink’s callback I only counter and didn’t do other time-consuming operations, even removing the h265encoder has the same effect.
Please apply the following items and check if there is improvement:
Set sync=0 to all sinks. This disables synchronization mechanism in gstreamer frameworks.
Execute sudo nvpmodel -m 2 and sudo jetson_clocks. All modes are listed in developer guide. Mode 2 is 4 CPU cores@1.4GHz. Please also try mode 0(2 CPU cores@1.9GHz)
My previous test environment was a 6-core 15W, and all sinkplugin was set objet-sync in false;
For others, I will try it by follow your suggestions;
But I personally think that the gStreamer framework or NvarGUS is more likely to have problems,
Because when two cameras are running and the number of queue-bins doesn’t exceed 2,it was work in 25fps, I think there is no problem with the capture capability of the hardware.
hello DaneLLL,
I had tried your all suggestion,but the resault was the same as before.
Can you help me out a little further,It looks like a software problem with nvargus and tee/queue,I think the performance of the NX is quite strong,these application shouldn’t be too stressful for it.
The default setting of buffer number in nvarguscamerasrc is
#define MIN_BUFFERS 6
#define MAX_BUFFERS 8
Please increase to 12 and rebuild/replace libgstnvarguscamerasrc.so for a try. You can see source code of nvarguscamerasrc in Jetson Linux | NVIDIA Developer
Links to L4T Driver Package (BSP) Sources
Hello,DaneLLL
It was the same result.Whether it’s running two cameras in a single process, or two single camera in two process.
I think nvargusCamerasrc is a great plugin that includes a lot of features that V4L2 doesn’t have.However, this problem currently occurs when using multiple sensors,this bug is easy to reproduce.
Hello,DaneLL
I had a new found. In the function bool StreamConsumer::threadExecute(GstNvArgusCameraSrc *src)(gstnvarguscamerasrc.cpp), I had printf the frame counter and it’s time,it was work well when only using a camera,it’s very standard 25 fps.
This means that some frames are not picked up on time,It’s not enough internal memory to capture? Or the delay in consumption caused the blockage for too long?
Hello,DaneLLL
The comand was work well in Jetpack4.6 by using terminal ,I want to run it on the C-code to further locate the problem.
Do you now how to set “video-sink=fakesink” in c-code,I set it but it to fakesink,but it general a autovideosink
Hello,DaneLL
I further located the bug,it has nothing to do with Tee or Queue,but it has to do with a plugin which name is “nvvidconv”;
As shown in the figure below,it can work well 25fps(3mintues 4546frames) without nvvidconv;
In your pipeline there is memory copy in nvvidconv plugin:
'video/x-raw(memory:NVMM),width=4000,height=3000' ! tee name=t ! queue ! nvvidconv ! 'video/x-raw,width=4000,height=3000'
It copies data from NVMM buffer to CPU buffer. So the performance is dominated by CPU cores. The resolution is > 4K so it shall hit constraint of CPU capability. For optimal solution we suggest keep NVMM buffer from sources to sinks. This would eliminate the memory copy and gives optimal performance on Jetson platforms.
Hello DaneLLL
Can Nvidia provide patches to configure support for more than 4K resolution?4000*3000 resolution is now common used in sensor(477/577/586 and so on).
