Announcing DeepStream 6.0
DeepStream 6.0 is now available for download on Devzone and NGC.
DeepStream 6.0 introduces a low-code programming workflow, support for new data formats and algorithms, and a range of new getting started resources.
Highlights:
  • Graph Composer. Assemble complex pipelines using an intuitive and easy-to-use UI and quickly deploy them with Container Builder.
  • Action Recognition. Create pipelines to easily identify action in your scene with the new pre-processing plugin. Specify regions of interest and the number of frames you want to process simultaneously.
  • Audio-video synchronization for applications such as broadcasting and web conferencing.
  • Automatic Speech Recognition (ASR) support. This new plugin performs automatic speech recognition on input audio data and outputs transcribed text.
  • Source code for the Python Bindings available on GitHub.com.
  • Tracker Updates
    • Performance Improvements
    • Easy integration of custom trackers.
    • New DeepSORT tracker.
  • Full REDIS support, previously alpha in version 5.1
  • New and updated sample applications are available in the SDK and on NVIDIA IOT GitHub. Check DeepStream documentation for additional details:
    • ASR
    • Body Pose Estimation
    • Emotion
    • Gestures
    • Many more.
Is the deepstream 6.0 compatible to Jetpack 4.6?
yes, it is.
The Ds 6.0 EA had separate repo for Jarvis apps with samples like
  • 2D bodypose
  • Facial landmark
  • Emotion
Are those included in the GA release?
Please check the release directly. Thanks
