Any rechargeable battery that is recommended or suitable used for Jetson TX2 and 12V DC high torque geared motor?
I bought both Jetson Tx2 and high torque 12V Dc geared motor. I would like to connect the motor onto Jetson TX2 which making it to be a rover. So, any suitable rechargeable battery(specifications) is recommended or suggested?
Thank you.
Hi, are you planning to use the battery to power supply the motor? A suitable charging control board is necessary too. Hope someone here has such experience.
Yes, I am planning to use the battery to power supply both Jetson TX2 and motor.
Don’t have an answer, but you’ll definitely want good isolation and regulation from the battery to the TX2 (separate from the motor). The inductive load would probably either cause reboot, shutdown, or other failure.
