AR0234 GMSL2 stereo Camera Issac ROS Argus Camera problem
Hi zhangpeng5,
Here’s the message on Hawk that you should expect with the correct DTB files:(captured on Nova)
Executing Argus Sample: argus_syncstereo
Argus Version: 0.99.3.3 (multi-process)
getSensorPlacement for sensor 0 is SENSOR_PLACEMENT_BOTTOM_RIGHT
Found : HAWK1
getSensorPlacement for sensor 1 is SENSOR_PLACEMENT_TOP_RIGHT
Found : HAWK1
Total Module Count is 1
Identified stereo camera module HAWK1 with the following 2 sensors connected:
0
1
Session[0] : add camera device 0
Session[0] : add camera device 1
PRODUCER: Creating stream[0].
PRODUCER: Creating stream[1].
Have you dumped your DTB for comparison? Have you considered ordering Hawk, which also has an AR0234 and is supported in Isaac ROS for the Argus camera? May I know why you are trying to build the stereo camera when the sensors and SerDes appear exactly the same as in Nova?
Hi glo,
It’s not the Hawk camera, it’s a camera we developed ourselves.
Unable to access to issac ros?
