I can’t really answer that. I can give you things to look at though.
Amplifiers are of course for the analog end. Some microphones are i2s, e.g., which are purely digital, which is typical of what you’d see in a cell phone (they are surface mount, and very tiny). There’s be no way to put an analog amplifier there.
Other microphones are purely analog, and do not use USB, while others are analog, but do use USB. In the case of a non-USB version you could just plug that into an amplifier, and then the amplified signal into the Jetson (you’d need something to plug it in to…that might be your main problem for anything not USB, although there is an i2s function). My guess is that due to the connector you are going to pick USB.
Some variations:
- You could get an analog USB microphone with the intent of actually cutting in to the wiring and installing a small amplifier. Not something to just purchase, so you might have some failed results (and costs) along the way.
- You could get a digital USB microphone and just use that.
- You could get a non-USB analog microphone, put it through an amplifier, and the amplifier itself could convert to USB (technically, it could convert to i2s, but I don’t think you’ll find that combination; if you did find that, then it might be the best choice).
Note that anything analog will tend to pick up EM noise on any cable which is not properly shielded. Digital wiring won’t have that problem, but digital won’t have the ability to add analog amplification.
I don’t know what your budget is, but I’m going to suggest you consider a cheap experiment before committing to some final choice (unless you find something that is built for the purpose): Get an inexpensive analog directional microphone. See how it does. Consider cutting in to this if you are comfortable soldering and working with electronics and splicing in a small low noise amplifier (lots of those available if you are flexible and have some experience soldering) if and only if performance is not sufficient (you’d splice in to the analog line that leads to the USB).
There so many individual ultra low noise op amps available for cheap it is hard to list any. You’d have to design that yourself, but if you have any engineering experience, it is trivial (making the circuit board is the hard part, but there are ways around that). Pre-built ultra low noise amplifiers which are small are out there, but less common.
You might want to start with something simple like a Google search.
Someone else may have a specific microphone suggestion, but anything USB or i2s should work. The only question is whether it is useful for your purposes. Incidentally, if it is USB and works on a desktop PC, then it should also work on a Jetson. Do you have a test microphone already which plugs into a PC? Try that.
See also:
https://www.amazon.com/directional-microphone/s?k=directional+microphone
