Are there some samples and specs for Vision Accelerator?
I found there are two vision engines on Xavier. I want to test some vision functions using Xavier, such as feature detection, optical_flow, warping, etc.
Are there some samples and specs for vision engines? How to use DMA, VPU memories and VPU? If there is a example for feature detection, I also want to know which algorithm the example use.
Thank you for asking this.
The vision accelerator in Xavier is called PVA.
The API and sample for PVA is not available yet but will includes in our future release.
