may I know those error report in comment #20 had already applied the pre-built libraries from comment #12, devtalk1065378_Oct29_prebuilts.tar.gz
is this failure only reproduce with SDR and WDR mode switch?
could you please also confirm the status by streaming all of them in the same sensor mode, also, how many cameras you’re working with?
thanks
I’ve hit this same problem on a Nano with a single raspberry (v2) camera attached, with the system sitting doing very little:
Sep 22 06:04:00 maverick-nano nvargus-daemon[4535]: SCF: Error InvalidState: Session has suffered a critical failure (in src/api/Session.cpp, function capture(), line 667)
Sep 22 06:04:00 maverick-nano nvargus-daemon[4535]: (Argus) Error InvalidState: (propagating from src/api/ScfCaptureThread.cpp, function run(), line 109)
Created 15Gb+ of syslog until the disk filled. Seriously guys, if you’re not going to fix the underlying problem, at least fix the syslog spamming so it doesn’t take the entire system down with it. This is a ridiculous bug to have around for years without a simple fix.
Rebooted nano, immediately spamming when it restarts:
top - 08:31:25 up 22 min, 1 user, load average: 2.95, 3.04, 2.43
Tasks: 225 total, 2 running, 223 sleeping, 0 stopped, 0 zombie
%Cpu(s): 23.2 us, 46.5 sy, 0.0 ni, 20.5 id, 9.4 wa, 0.3 hi, 0.2 si, 0.0 st
KiB Mem : 4059356 total, 508512 free, 828656 used, 2722188 buff/cache
KiB Swap: 2029664 total, 2029664 free, 0 used. 2921924 avail Mem
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
3386 syslog 20 0 359388 7136 3104 S 133.3 0.2 28:45.98 rsyslogd
1906 root 19 -1 80012 25940 25144 R 99.3 0.6 21:45.12 systemd-journal
4543 root 20 0 9.805g 153676 33120 S 39.9 3.8 7:57.23 nvargus-daemon
1854 root -2 0 0 0 0 S 2.6 0.0 0:10.21 mmcqd/0
6385 root 20 0 0 0 0 D 2.0 0.0 0:00.74 kworker/u8:3
4546 mav 20 0 30324 22312 8776 S 1.0 0.5 0:11.85 python3
5299 mav 20 0 892936 44380 18744 S 0.7 1.1 0:08.68 mavros_node
6995 root 20 0 9180 3652 2904 R 0.7 0.1 0:00.11 top
4683 mav 20 0 258504 30708 8224 S 0.3 0.8 0:06.30 python3
5276 mav 20 0 258320 29868 8508 S 0.3 0.7 0:06.41 python3
System is quiet except for all the logging activity. It runs a process doing simple video streaming through gstreamer. Perhaps the nvargus-daemon is self-triggering stress conditions with the insane amount of logging?
This insane logging activity only occurs when gstreamer is active. The system is running Jetpack 4.4 with the latest kernel 4.9.140-tegra.
The issue was never fixed AFAIK. However, the combination of the 32.2 release (jetpack 4.2.1 IIRC) and bumping the thread priority for argus threads way up (we use nice -15) basically eliminated this particular problem for us. We run six cameras with pretty heavy system load for several hours a day, and haven’t hit it in a while. We are using the argus library directly, not going through gstreamer.
@kes25c@SanjayD@sunxishan I add a repo with a description of all fixes for the camera work. Included information how run python opencv example and avoid error (Argus) Error InvalidState: (propagating from src/api/ScfCaptureThread.cpp, function run(), line 109)
and fix for the rebooting system (bludroid_pm module)
Hope it helps.
