Dear all,
I have some issues with associate construct
The following code
program test
implicit none
type type_a
complex(8), dimension(:,:), allocatable :: z
end type type_a
type(type_a) :: a
integer, parameter :: n = 2
integer :: i, j
allocate(a%z(n,n))
do j = 1, n
associate ( array => a%z(:,j) )
call do_stuff( array, n )
end associate
end do
do i = 1, n
print*, a%z(i,:)
end do
contains
subroutine do_stuff( b, n )
integer, intent(in) :: n
complex(8) :: b(n)
integer :: i
do i = 1, n
b(i) = (1,1)
end do
end subroutine do_stuff
end program test
Your program compiles without a problem using the 17.1 release, out
as soon as we can get it out. There was a bit of work on ASSOCIATE for the
17.1 release.
Dear PGI
I try to build this test program but it doesn’t work with 18.3 version
program test
implicit none
integer :: i, j
integer, parameter :: n1 = 5
integer, parameter :: n2 = 5
real(8) :: dx
real(8), dimension(n1,n2) :: derivs
dx = 1.0_8 / real(n1, kind=8)
do i = 1, n1
do j = 1, n2
derivs(i,j) = (i-1) * dx
end do
end do
associate( h => [(dx**i, i=1, ubound(derivs,1))] )
do j = lbound(derivs,2), ubound(derivs,2)
derivs(1:,j) = derivs(1:,j) * h !(1:)
end do
end associate
do i = 1, n1
write(*,"(5f7.3)") ( derivs(i,j), j = 1, n2)
end do
end program test
This last issue looks like it was addressed sometime around the transition to the NVIDIA HPC compilers and nvfortran. Sorry for not replying earlier, and not quite sure which exact release, but it appears to work at least a year back.
