I try use DLSS sdk with Vulkan…but not only 472.33 nor the latest geforce experience drivers works…well is not finding any Vulkan gpu device…it is a well know issue for this Notebook?
I tried all the well know steps…from clean install to other/old drivers but non of them seems to work plus LunarG Vulkan SDK is failing to display info!
Relaying on ASUS drivers was ok…RayQueries even is not supported by the 456…I was able to make them work…but DLSS SDK samples are impossible to run based on drivers outdated…interestingly NGX SDK samples with CUDA are ok.
How can I sort this out so I can continue developing in Vulkan with features I know the RTX 2060 is capable todo?
Thanks in advance
