L_F
October 22, 2008, 4:04pm
#1
Hello! The problem: atomicExch (and others atomicXXX) is not recognized by nvcc. The card is Quadro FX1700, compute capability 1.1, VS2005, CUDA Wizard 1.2
Code:
#include <cutil.h> …
#include <sm_11_atomic_functions.h>
global void kernel1(…) {
… zzz=atomicExch(&row[ix], row[ix]+xxx); …
The compiler error:
Compiling…
testcudadll.cu
c:\cuda\include\common_functions.h(56): warning: dllexport/dllimport conflict with “clock”
C:\Program Files\Microsoft Visual Studio 8\VC\INCLUDE\time.h(176): here; dllimport/dllexport dropped
testcudadll.cu(257): error: identifier “atomicExch” is undefined
1 error detected in the compilation of “C:\DOCUME~/tmpxft_00000f64_00000000-6_testcudadll.cpp1.ii”
What could cause the problem? Thanks.
To use the atomic functions you need to add “-arch sm_11” to your nvcc command line.
Hi
I have the same problem but when I added “-arch sm_11” to my comand line, it gave me this error "nvcc fatal : redefinition of argument ‘gpu-name’ "
I am now using CUDA VS Wizard 2.0 for VS2005 and my graphics card is GeForce 8500GT. If I am not wrong, 8500 is of compute capability 1.1, so I think the problem lies in the command line.
The default command line given is
nvcc.exe -ccbin "C:\Program Files\Microsoft Visual Studio 8\VC\bin" -I"C:\progra~1\CUDA\include" -I"C:\Program Files\NVIDIA Corporation\NVIDIA CUDA SDK\common\inc" -O0 -D_DEBUG -D_CONSOLE -arch sm_10 -code sm_10 --host-compilation C++ -g -c -m 32 -o "Debug\main.obj" -odir "Debug" -ext none -int none main.cu
I am thinking that if I change the flag, “-arch sm_10” to “-arch sm_11”, it might solve the problem, but I cant edit my command line…
can anyone help me on this?
EDIT
I tried to change the default (in Microsoft Visual Studio 8\VC\VCProjectDefaults\cuda.rules ) to -arch sm_11 and -code sm_11 and it worked.
kyzhao
November 17, 2008, 9:20am
#5
Hi
EDIT
right key on project-> cuda -> advanced -> 1.1 (hardware) Arch&1.1 (hardware) code
Could you give more detail on how to modify the command line? I am new to Visual Studio and a bit lost. I did not understand:
“right key on project-> cuda -> advanced -> 1.1 (hardware) Arch&1.1 (hardware) code”
The only reference to to a nvcc.exe command line is in the “custom build rules”.
Mine shows:
nvcc.exe [AllOptions] [AdditionalOptions] $(InputFileName)
Any help would be greatly appreciated.
kyzhao
November 20, 2008, 5:15pm
#7
Mine shows:
right key on project->properties->cuda -> advanced -> 1.1 (hardware) Arch&1.1 (hardware) code
BTW, you can have a look at this video which i made for beginner to make a cuda project step by step in Visual Studio.
When I Right click on project -> properties ->???
I find no reference to CUDA.
I also clicked on the link to your homepage and can not find the video you mentioned.
Thanks for the help
kyzhao
November 22, 2008, 9:21am
#9
