Basically what I am trying to do is to transform my GPU into a DSP to process audio in real time. I tried using PortAudio API, but couldn’t make it work with CUDA, using nvcc or gcc compiler. Is there anything known that I could use to send the processed data into the audio output buffer ?
Related topics
| RealTime DSP w/CUDA on Linux Product Selection Advice | 1 | 3363 | March 16, 2008 | |
| Real Time Audio Processing AudioMulch 1.0, VST-Plugin, Cuda SDK 2.3 | 5 | 10239 | October 23, 2009 | |
| Using GPU for audio DSP | 1 | 2529 | July 9, 2015 | |
| GPU processing with DAW | 1 | 2686 | August 18, 2019 | |
| Audio and mulitmedia? Question on cuda | 3 | 2930 | January 12, 2009 | |
| Audio codec implementation using CUDA | 0 | 860 | April 25, 2013 | |
| VST - CUDA integration | 16 | 20069 | April 29, 2010 | |
| Dogotal Sound Processing with CUDA cores | 3 | 2057 | February 7, 2017 | |
| CUDA for audio synthesis? transform graphics chip into audio chip | 1 | 16247 | August 1, 2008 | |
| Real-time computing with CUDA | 4 | 3388 | October 6, 2009 |
