Not really.
Which was the last driver where audio worked, does that still work?
Why are you using that DP2HDMI dongle, does audio work if you connect it to an HDMI output or does that card not have an HDMI out?
Card doesn’t have any HDMI outputs, only displayports and DVI. 410.73 worked, just seems like it got removed from the repository, so downgrading with the package manager doesn’t seems like an alternative :-(
Tried enabling that, removes the plymouth bootscreen, no effect on the audio. I find it rather amusing that the computer claims that the screen I’m viewing on is unplugged.
Exactly same symptoms for me as well. No audio. No ELD information.
Worked for me at 4.18 + 39X (could not remember now). Does not work on 4.19.5 + 415.22
I’m using nvhda module to activate PCIe function for audio.
Could found this suspicious log in the dmesg:
[ 41.202159] snd_hda_codec_hdmi hdaudioC1D0: HDMI: invalid ELD data byte 0
Same problem for me since 415.x, 410.x works fine. Too bad, Kernel 4.20.x needs 415.x. Pavucontrol sees all of my HDMI audio outputs but states them all as “unplugged”. This seems to be the problem.
