Audio2face - generate blend shapes? before or after?
I notice when i generate the blend shapes in audio2face, they’re all the same. Do we need to generate the shapes before importing the mesh into Audio2face or does audio2face take care of that? … would be great if A2F did that task :D
Coming from Blender.
Thank you.
David
Hi @user166893! Welcome to the community!
The Blendshape Generation tool should allow you to generate a set of blendshapes from a custom neutral mesh. If you run your mesh through the character Transfer process, select your mesh then click “Blendshape Transfer”. A full set of shapes should be generated and available for export as USD for use in any DCC application.
If this isn’t working for you, would you be able to provide me with your log files so that we can identify where the problem might be? You can find them here: Omniverse App Logs: C:\Users\<USERNAME>\.nvidia-omniverse\logs\Kit\Audio2Face
