Is there AV1 encoder support using v4l2? The samples on jetpack only covers H264, H265, VP9…
Those samples seem to indicate that in order to use AV1 is needed to tell the kernel the output plane format is AV1, and that uses defines on videodev2.h :
/* compressed formats */
#define V4L2_PIX_FMT_MJPEG v4l2_fourcc('M', 'J', 'P', 'G') /* Motion-JPEG */
#define V4L2_PIX_FMT_JPEG v4l2_fourcc('J', 'P', 'E', 'G') /* JFIF JPEG */
#define V4L2_PIX_FMT_DV v4l2_fourcc('d', 'v', 's', 'd') /* 1394 */
#define V4L2_PIX_FMT_MPEG v4l2_fourcc('M', 'P', 'E', 'G') /* MPEG-1/2/4 Multiplexed */
#define V4L2_PIX_FMT_H264 v4l2_fourcc('H', '2', '6', '4') /* H264 with start codes */
#define V4L2_PIX_FMT_H264_NO_SC v4l2_fourcc('A', 'V', 'C', '1') /* H264 without start codes */
#define V4L2_PIX_FMT_H264_MVC v4l2_fourcc('M', '2', '6', '4') /* H264 MVC */
#define V4L2_PIX_FMT_H263 v4l2_fourcc('H', '2', '6', '3') /* H263 */
#define V4L2_PIX_FMT_MPEG1 v4l2_fourcc('M', 'P', 'G', '1') /* MPEG-1 ES */
#define V4L2_PIX_FMT_MPEG2 v4l2_fourcc('M', 'P', 'G', '2') /* MPEG-2 ES */
#define V4L2_PIX_FMT_MPEG2_SLICE v4l2_fourcc('M', 'G', '2', 'S') /* MPEG-2 parsed slice data */
#define V4L2_PIX_FMT_MPEG4 v4l2_fourcc('M', 'P', 'G', '4') /* MPEG-4 part 2 ES */
#define V4L2_PIX_FMT_XVID v4l2_fourcc('X', 'V', 'I', 'D') /* Xvid */
#define V4L2_PIX_FMT_VC1_ANNEX_G v4l2_fourcc('V', 'C', '1', 'G') /* SMPTE 421M Annex G compliant stream */
#define V4L2_PIX_FMT_VC1_ANNEX_L v4l2_fourcc('V', 'C', '1', 'L') /* SMPTE 421M Annex L compliant stream */
#define V4L2_PIX_FMT_VP8 v4l2_fourcc('V', 'P', '8', '0') /* VP8 */
#define V4L2_PIX_FMT_VP9 v4l2_fourcc('V', 'P', '9', '0') /* VP9 */
#define V4L2_PIX_FMT_HEVC v4l2_fourcc('H', 'E', 'V', 'C') /* HEVC aka H.265 */
#define V4L2_PIX_FMT_FWHT v4l2_fourcc('F', 'W', 'H', 'T') /* Fast Walsh Hadamard Transform (vicodec) */
#define V4L2_PIX_FMT_FWHT_STATELESS v4l2_fourcc('S', 'F', 'W', 'H') /* Stateless FWHT (vicodec) */
There is no define for AV1. Is there sample code on how to use AV1 encoding?
