Sorry to disturb you, I am trying to integrate the AV1 encoding/decoding codec to my embedded application (by using the benefit of AV1 hardware encoder/decoder present in jetson Orin). I am able to encode/decode frames successfully but I can not retrieve timestamp of decoded frame. The decoding process is asynchronous and I need the decoded frame timestamp for synchronizing my output frames (the v4l2_buf.timestamp obtained after dequeue the capture_plane).
I reproduced the issue with the samples provided in Jetpack. In our application we are using similar approach of copy-timestamp from your sample and it works properly with H264/H265. Using the same approach, I downloaded the same video from your blog (the jockey video) and I ran the following commands:
Encoding:
./video_encode ./Jockey_3840x2160.yuv 3840 2160 AV1 ./Jockey.av1 --copy-timestamp 0
Decoding:
./video_decode AV1 --disable-rendering --stats --copy-timestamp 0 120 --input-nalu -o test.yuyv ../01_video_encode/Jockey.av1
I can’t retrieve the timestamp of decoded frame with your sample using AV1:
Creating decoder in blocking mode
Opening in BLOCKING MODE
Set governor to performance before enabling profiler
NvMMLiteOpen : Block : BlockType = 282
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 282
Setting frame input mode to 0
It's a valid IVF file
Starting decoder capture loop thread
Video Resolution: 3840x2160
Video SAR width: 0 SAR height: 0
Decoder colorspace ITU-R BT.601 with standard range luma (16-235)
Query and set capture successful
[0]dec capture plane dqB timestamp [0s0us]
[1]dec capture plane dqB timestamp [0s0us]
[2]dec capture plane dqB timestamp [0s0us]
[3]dec capture plane dqB timestamp [0s0us]
[4]dec capture plane dqB timestamp [0s0us]
[5]dec capture plane dqB timestamp [0s0us]
[6]dec capture plane dqB timestamp [0s0us]
[7]dec capture plane dqB timestamp [0s0us]
[8]dec capture plane dqB timestamp [0s0us]
[9]dec capture plane dqB timestamp [0s0us]
[10]dec capture plane dqB timestamp [0s0us]
[11]dec capture plane dqB timestamp [0s0us]
[12]dec capture plane dqB timestamp [0s0us]
End of stream
Input file read complete
Got EoS at output plane
Got EoS at capture plane
Exiting decoder capture loop thread
----------- Element = dec0 -----------
Total Profiling time = 3.06821
Average FPS = 65.1846
Total units processed = 201
Total Profiling Time = 0 sec
App run was successful
I saw from samples help that copy-timestamp is only supported for H264/H265 but I am looking for a way to also use it with AV1. Is there a way to associate timestamp to frame during the AV1 decoding process by using copy-timestamp or other tricks ?
Thank you very much in advance,
Tanguy
