Q1. AWS Panorama uses the AGX as its hardware.
What is the pin define of AGX need to support AWS panorama? For example, can I just use AWS dev kit to support these LED and button functions? Or any OEM gpio pin need to connect out?
|Power control |Push-button|
|Reset |Momentary switch|
|Status and network LEDs |Programmable 3-color RGB LED|
Q2. To run the AWS Panorama on AGX, Does AGX dev kit need to do any change for that?
Thank you!
Stan
